Headswap question
Headswap question
Have some heads going on my z28 this weekend, wondering if i should clean the carbon off the pistons while i have the heads off..
car has 107k miles
Clean them or not to clean them?
car has 107k miles
I left the old lifters & trays in until after the cleaning, plus stuffed rags in the lifter trays. I did each cylinder one at a time at TDC. I used denatured alchohol with non metallic scotchbrite pads and scrubbed my butt off. It will take you 4-6 hours to do it right....don't get discouraged...take a break and come back at it! After you are done....do it again and wipe each cylinder with a clean rag as you rotate the engine to remove any loose debris. When all is clean take a rag with fresh oil and wipe down cylinder walls.
Wow, about two threads down we just answered the same question...
https://ls1tech.com/forums/generatio...f-pistons.html
I can't imagine being in there and not cleaning up the carbon deposits. I would highly reccomend you clean everything really well. Also, make absolutley certain that you clean out the bolt holes really well. Get EVERYTHING out of them, it takes a while, but if you don't, you are buying a new block real soon. Are you going with the ARP bolts or a new set of stockers? We used stock bolts, but I will tell you that getting the final torque angles is not terribly fun.
Remember too that that carbon build up can cause hot spots and pre-ignition...
