How hard can you push a 1" wheel adapter?
I got some H&R 25mm (1") hub centric wheel adapters just to push the rear wheels out on my Z28 for looks.
But plans have changed and I ended up with a set of SS wheels and new tires.
So I decided to try the adapters anyway.
With the new wheels, tires, and adapters it pushes the wheel out approx 2" so now it's almost even with the wheel opening.
The car was running low 12's at the track, and a 1.8 0 to 60'
It's got a circle d 3600 converter so it hits the tires hard. I also like to take corners faster than most when traffic allows. (highway on/off ramps mainly)
Thats it. Now that I typed it out it seems like a dumb question.
Anyway at some angles it doesn't look right, so I may take them off.
How much abuse can these handle?
H&R Trak+® Wheel Spacers
If you've ever seen a sleek, European sedan with that oh-so-low street stance and a bulging wheel/ tire combo that just barely tucked under the wheel wells, chances are that car was fitted with H&R TRAK+ wheel spacers. TRAK+ wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling, greater safety and of course, the sleek style you've been looking for.
TRAK+ wheel spacers are made from a proprietary aluminum/magnesium alloy which is not only incredibly strong, but also very light weight (up to 70% lighter than a comparable steel product). TRAK+ wheel spacers are then hard anodized to ensure a tough, durable finish that is resistant to chipping, scratching and oxidation. Hub centric for the highest level of accuracy, TRAK+ wheel spacers are 100% made in Germany under ISO 9001 Quality Assurance standards, and meet the rigid safety criteria of the German TÜV.
Whether you want improved handling, increased safety or simply want your car to make a statement about your individual style, TRAK+ wheel spacers can help you accomplish your goal.
They say to do that with wheels but I never have, and never had a problem with it.
I've got like 10 miles on all this, had it up to 60, rides smooth. Need to get out on the highway tomorrow and open it up. New tires, used wheels, spacers...I hope they all work well together.
I have been using them for a few months. The only thing I wonder about is I hade to cut my studs down to 1". They have had no issues though. I have checked them a few times and they were fine.
Can someone who is running the (25mm) 1" adapter on stock wheels post pictures? I found this page, https://ls1tech.com/forums/wheels-ti...-trans-am.html, but would like better pictures. Has anyone used the (20mm) 3/4" spacer?
bolt-on adapters are fine to push hard. Spacers are what you need to be very careful of. Like others said, torque them properly and then do it again 50-100 miles later to be sure..probably check every so often when you get bored, but I know of a lot of people who've had them on their 60's muscle cars and track them (road course HPDE) often with no problems..
