Drag Racing Tech
25.2/25.3 good to 6.0 sec. C5 Corvette LSx Build
Old 04-29-2009, 11:13 PM
dacajun's Avatar
Default 25.2/25.3 good to 6.0 sec. C5 Corvette LSx Build
25.3 good to 6.0 sec at over 200mph garage built C5 Corvette LSx Build.
Here's some pics of what I have going on in my garage. I wanted to build something other than your typical F-body and your every day mustang. So decided to go with a Vette.
This car will be good to go 6.0's at over 200mph. It'll be a four link rear suspension with the rear frame rails still in place. Most santioning bodies today will require cars going over 200mph to have a full floater rear housing. I'm running a Bears Performance fab 9 4130 housing with Mark Williams floater kit along with the MW 40 spline gun drilled axles. Oh yea, and the Mark Williams dual rear calipers. Bears Performance promod fourlink kit, wishbone, and torsion bar. The rear shocks are Santhoff double adjustable. Front shocks are strange double adjustable.
I am doing all the fab work, bending and fitting of all the tubing.
Began the project by building my own tubing bender. Bought the plans over in Ebay. Purchased the 1",1 1/4", 1 1/2", 1 5/8" dies from Pro-tools. I also purchased a Mitler Bros. tubing notcher.
Had to have a tig welder.
Ya gotta have some parts. Well lots of parts. Here's a just a few.
BTW, This car is being built and funded by myself. No sponsors at this time. However that is always open for discussion.
Weld Aluma star spindle mount wheels. Notice the four piston calipers. These are not available as a kit for spindle mount wheels. So I had source the correct disc and hats to put together something that'll stop a car a the weight these cars are having to weight.
A little front suspesion work. Redoing the whole thing by fabricationg some upper and lower control arms along with a kingpin with a stange spindle. This will also tuck the front wheels in so they don't have that flush fit with the front fenders. I am also increasing the caster to be able to go to total of postive 10degs. Lots of adjustment. Should go nice a straight. All parts constructed out of 4130.
More to come.......
Enjoy the pics.
-Dave
The following users liked this post:
slowpoke96z28 (07-29-2021)
Old 04-29-2009, 11:31 PM
dacajun's Avatar
And now for a little bit of rear suspension stuff.
Old 04-29-2009, 11:44 PM
sr71bbjr's Avatar
OMFG! That looks killer DAVE!!! Nice to see you went with the 4 link after all!
Bryan
Old 04-29-2009, 11:50 PM
dacajun's Avatar
Thanks Bryan, I appreciate the compliment. I got a few more pictures to come....
-Dave
Old 04-29-2009, 11:57 PM
Kingsize's Avatar
Damn, Nice looking work.
Subscribed!
Old 04-30-2009, 12:11 AM
dacajun's Avatar
Ok, how about some of the good stuff. The chassis.
The original rear Frame rails will go back in once I get all the rear stuff completed.
I'm building the car with some versatility in mind. I will run the local Texas True Ten Five Extreme street class. But wih the adjustable rear shocks and four link I can always run a taller rear tire and have all the adjustabilty in the rear suspension I'll ever need. It should also be very strong. Hopefully it'll hold alot power. You never know when a big cubic inch big block with a set of twins may find it's way between those front frame rails.
-Dave
Old 04-30-2009, 12:48 AM
dacajun's Avatar
Ok, now let's move on over to the front of the car. Gotta have some sort of cooling. I designed a removable radiator support basket. Take a close look at the pictures. The rad frame is hinged and it plugs right into the front lower frame. If for any reason the radiator needs servicing or to be replaced it'll be a snap. Also, I may end up using the intercooler ice box to cool the motor. If that's the case the radiator comes right out. But that would not be much of a street car would it. I do plan on driving the car on the street also. It will be streetable.
Old 04-30-2009, 01:22 AM
dacajun's Avatar
Now for the power adder. I wanted this to be versatile as well. To run the TTT.5 extreme street class I will be limited to an 88mm turbo. No problem, it'll be on a T-6 flange. Heck unbolt that liitle 88 and bolt on a 106 or up to a 116 for that matter. Now if I decide to go with some twins, and I'm sure some where down the road I may just do that Big cubic inch BBC with some pro-mod 90's, that won't be a problem. Heck the rear suspension should handle it so why not?? So I designed a removeable frame for the single turbo. Latter on I can build a frame that'll hold a set of twins and it will set right in place with ease.
I incorporated what I refer to as saddles. These are very nice as all you have to do is set the turbo frame on these and it automatically aligns the bolt holes.
I guess you can say it's all modular. More to come...
-Dave
Old 04-30-2009, 01:47 AM
dacajun's Avatar
One more picture for the night. Here's one with a rear wheel and a quarter fender in place. It should have a sick stance. The car is being built to sit 4" off the ground.
Time to get some sleep.....
-Dave
Old 04-30-2009, 03:26 AM
letsrunem's Avatar
Unbelieveable! Awesome work!
Old 04-30-2009, 05:18 AM
98CamZ28's Avatar
Wow, very sick build you have going there, can't wait to see the future progress. This car should be flying
Old 04-30-2009, 06:15 AM
LS1Tech Sponsor
MADMAN's Avatar
Very nice and I love the creativity. I like the rear shock mount idea.
__________________
www.madmanandcoracing.com
225-343-9029
Old 04-30-2009, 06:27 AM
Kingsize's Avatar
The amount of time and effort put in this build is insane.
Sick *** build guys! Keep the pics rolling in.
Old 04-30-2009, 06:36 AM
z28rob18's Avatar
wow! thats some awesome work there. great job
Old 04-30-2009, 07:29 AM
b.lee's Avatar
That is Insane.
Old 04-30-2009, 09:13 AM
Gen414's Avatar
Dacajun, when we talked through PM, I got an idea your ride was gonna be pretty killer, but NOT to this extreme...holy ****!!! This is gonna be SICK when completed, I LIKE, alot! All those "little" things you did, saddles, hinged rad support,etc...those take lots of time...from the thought, designing, fab'n, fit'n, fab'n more!!!! Seems like my little old chassis build I'm doing, just got the smack down thrown on it Guess I gotta start over
Old 04-30-2009, 09:21 AM
Carbed4thGen's Avatar
Absolutely sick home build!
Old 04-30-2009, 09:27 AM
Phantom's Avatar
Wow...that's nothin short of amazing
Old 04-30-2009, 09:31 AM
tektrans's Avatar
Old 04-30-2009, 09:34 AM
7 Second Club
Phil99vette's Avatar
Car looks awesome, should be an easy 4.5-4.6 second ride in the 1/8.
Quick Reply: 25.2/25.3 good to 6.0 sec. C5 Corvette LSx Build
