Cam Size
Old 04-29-2009, 11:15 PM
00 SiLvEr SS's Avatar
Default Cam Size
im planning on building a cam only car for right now and i need to know what would you reccomend as a cam from texas speed for a basic bolt on motor im not lookin for sometihing majorly over the top i want a nice sound a good power gains
Old 04-29-2009, 11:21 PM
willizm's Avatar
I'm curious to know as well. I've read the sticky and seen alot of people say it all depends on what you want to do. The problem is that I don't know how to correlate the sizing to what I want to do. I want something that is a weekend town piddler, but absolute bad *** at the same time. I have a couple other DD's. I'm not going to do anything until I get all the exhaust done, so I've got time to figure it out.
Old 04-29-2009, 11:24 PM
CUR 4 VNM's Avatar
get a custom cam by pat g or predator Z!!! best thing you can do
Old 04-29-2009, 11:28 PM
ABQ99TA's Avatar
Call TSP and talk to them.
Old 04-29-2009, 11:58 PM
Kingc8r's Avatar
+1
Old 04-30-2009, 12:04 AM
flintwrench69's Avatar
I posted this question a month or so ago. The answer I got was TR224 or TR228 cam have been very proven performers with stock heads. I checked the specs & expected power gains on texas speeds site. I wanted something that would give a decent gain, but not too radical. I got the TSP 228 cam package with PRC dual spring kit, hardened pushrods. For the price, nobody else offered this kit with the PRC duals, comes with valve seals & titanium retainers. I also got the ported LS6 oil pump, gasket package, & ARP crank bolt( highly recommend getting this as its longer & makes installing the crank pulley a breeze). I bought an LS2 chain in the classifieds. I just got the install done this morning, I put 60 miles on it so far & it pulls pretty hard. So far I really like this cam, almost stock idle, slight lope with a nice power increase. Texas speeds cam packages are hard to beat, but I am sure Patrick G & Predator Z know their stuff when it comes to cam selection.
Old 04-30-2009, 12:05 AM
2002SS#1811's Avatar
Check SpeedInc. nice custom grinds.
www.LS1SPEED.COM
SPONSOR............
Old 04-30-2009, 09:27 AM
yeah i want a good lope but not a rediculous one
Old 04-30-2009, 12:58 PM
teke184's Avatar
228r
or have them grind you up an "el torro"
Old 04-30-2009, 01:57 PM
now will i get good performance out of the 228
Old 04-30-2009, 02:59 PM
NC98Z's Avatar
Is your car an A4 or a M6?
If its an A4 is it a stock or aftermarket stall convertor?
Are you running the stock rear gears or have you changed the gear ratio?
Old 04-30-2009, 03:20 PM
my cars a a4 with the stock stall and 373 gears
Old 04-30-2009, 05:22 PM
TooLateVTEC's Avatar
With any camshaft you WILL WANT a stall converter or its just not going to act right. It will idle high in park and the car will lunge/jerk pretty bad when you drop it in gear and you dont want that.
If you go cam only I would say get a 224 duration (@.050) or if you want a little more lope go with the 228 duration (@.050).
If your going to do heads at the same time, you could use a 230-ish duration camshaft and use a set of heads that are around 62cc combustion chamber, use an .045 thick gasket to get the compression around 11:1 and you'll be set. An LS6 intake and a set of headers would be a must...even though my car doesnt have them yet.
Either way you go, get the cam on atleast a 112 LSA.
Old 04-30-2009, 05:27 PM
so without a stall my car will act funny as hell
Old 04-30-2009, 05:32 PM
With a 224 cam and larger, I would say yes.
In my 87 IROC, the hydraulic roller cam I had in that was 218/224 duration @ .050 and I used a 2400 stall in that thing.
EDIT:
Welcome to the world of HOT RODDING !!
Old 04-30-2009, 07:47 PM
I just installed my 228 cam so only put 60 miles on it. So far, I like it, drives real good, idle is just a lil more lope than stock with the 114 LSA. It pulls hard, thats untuned too. Texas speed says it should be a 40 whp increase. I really like the power I got from this cam. A few recommended this cam, & it was said theres power everywhere with it, I agree. It just depends on what your goals are. From what you seem to be asking, I think you will be happy with the performance with either the 224 or 228 cam. I wouldnt go any smaller than that. Another reason I went with it is if I went too much bigger than .600 lift, ptv clearance becomes an issue. I am getting the car dynotuned next friday so I will post up the numbers it puts down. You will want a stall with any cam you decide on though.
