01 z28 need alil help
ok so i have a 01 z28 6speed, 140k, isnt running. sometimes it will fire up but die, put a guage on the rail it said 0, today it fired up though an died.. an there was alittle bit of pressure on the check valve cap, i cracked the cap off and gas shot out, im thinkin its the pump.. i dont wanna spend 550 for a stock assembly, i was thinkin of the walbro and the write up seems pretty good but it wont let me view the pics.. if i buy the racetronix pump, just the pump. will that be easyer plug an play wise? need some help! thx in advance!
Yes the Racetronix is very easy PnP wise but installl the Wire kit with it the added amp draw from the new pump will be too much for the factory wiring. We keep these in stock.
Nate
Nate
