Problems ASR switch
Old 04-30-2009, 08:27 AM
1sicss's Avatar
Default Problems ASR switch
I was driving home today and the ABS INOP light turned on as well as the ASR OFF light on the gauge cluster then I noticed that the little ornage light on the switch as well is off won't come on. What's going on? HELP!!!
Old 04-30-2009, 09:07 AM
teke184's Avatar
sounds like a loose sensor plug on one of the wheels.
if the abs senses a problem, it nullifies the ASR i beleive.
try checking the plugs
Old 04-30-2009, 11:33 PM
spy2520's Avatar
this is correct. Any ABS problem is gonna turn off ASR. Also check for broken wires going to the wheel speed sensors or debris by the sensor or damage to the ABS rings.
