ls1 and t-56 g-body
ls1 and t-56 g-body
I need some help on a ls1 6speed swap in a 1980 malibu.I have a donor car wich is a 2002 ss camaro.Do i need the clutch pedals, fans radiator?What abount the slave cylinder? Any help on this swap would be greatfull.Thanks David
sawzall wielding director
You can use the f-body rad if it fits, otherwise the malibu one should work just fine. Use the f-body fans if they fit, or I used fans from a mid 90`s FWD 3800 car cause they fit and were cheap, just had to make mounts. Mines an auto so I don`t know about pedals fitting but I would think the f-body pedals would be a start, just get a sawzall and welder
I built a custom clutch pedal off of the stock monte pedals, by using John b's design to make mine. Here is his website for the swap
http://www.ls7montess.com/
