no 3rd or 4th in 4l60e
Old 04-30-2009, 12:42 PM
bigboy t/a's Avatar
Default no 3rd or 4th in 4l60e
Ok yesterday driving home i noticed that it wont go into 3rd or 4th gear at all it just free revs when it tries to shift into third. first and second are fine is just when going into third or 4th the rpms shoot up like in neutral. Can anyone help me out here the car is my DD so i need it back on the road bad.
Old 04-30-2009, 01:51 PM
LS1Tech Sponsor
performabuilt's Avatar
Unfortunatley you have lost the 3-4 clutch set and the trans will need to be rebuilt or replaced .
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-30-2009, 02:07 PM
bigboy t/a's Avatar
dam did not want to hear that but thanks.
what causes 3-4 clutch set to give out?
Old 04-30-2009, 02:14 PM
Bret@EFIAlchemy's Avatar
Pretty much just normal wear and tear, since 3rd and 4th are essentially the same clutches. ive went through 2: 3-4 clutch sets.
Old 04-30-2009, 02:18 PM
bigboy t/a's Avatar
is it common for some hole in the wall shop not replace 3-4 clutch set when it is being rebuilt. The reason i ask is because before i owned the car the trans had already been rebuilt by some shop and supposedly they replaced all the clutches but dont know about that cause they left a hole bunch of crap loose under the car
Old 04-30-2009, 02:23 PM
LS1Tech Sponsor
It would be replaced but not upgraded normally with a regular rebuild in a regular shop.
__________________
Call 888-744-6542
Old 04-30-2009, 02:38 PM
bigboy t/a's Avatar
ive always heard of people saying that the stock 4l60e trans that came with the f-bodys were crap until they were upgraded internally. Is this true or a bunch of crap?
Old 04-30-2009, 04:09 PM
01ssreda4's Avatar
^^^ true for the most part but i cant seem to kill mine...
Old 04-30-2009, 04:14 PM
Deranged Rat Fink
badjuju342's Avatar
Been there , done that . Yep, you need a rebuild.
Old 04-30-2009, 05:44 PM
BlownVette 2001's Avatar
Pretty much need to be upgraded or replaced 4L80.
Old 04-30-2009, 06:59 PM
am_muscl's Avatar
i had the same problem. my 3-4 clutch packs were toast. you can get a pretty good deal on a rebuilt unit for about $1k, especially in Texas there should be quite a couple.
