Full exhaust on... Do I need to keep the Y-pipe support brace?
I've just installed ARH headers & Y-pipe, and I have to say I'm VERY pleased with the fit. It was a straightforward install without any problem encountered.
However, I've forgotten to put back that support brace for the exhaust, the one that supports the exhaust where the Y junction is. It's a piece of stamped steel painted black with 2 bolts on each side that attach to the floor. I've just tried to bolt it back on but it won't fit. Maybe I could try to make it fit... but I'm asking myself "do I really need this brace?".
Would I be OK without it, or does my exhaust risks falling down?
If I do need to put it back on, could you please tell me how it goes back on? I can't remember if the side with the square cut-out goes on the driver's side or passenger's side.
just finished my ARH header with catted Y install.
i had the same problem, the brace WILL NOT go back in. The merge of the ARH ypipe is just too big.
I am planning to call them tomorrow and check to see if it is suppose to fit back or not.
tony
tony
