horrible headache of a problem
also posted on cz28.com
the car: 95 a4, performabuilt 4l60e, performabuilt 3200 stall convertor, new tr6's, new plug wires, new msd opti, msd coil all within the last 1000 miles. new o2's within the last 1500. also has lt headers with a bullet dumped off of the y-pipe, gears, elbow and cai
the problem: car has a bad vibration under a load, most noticeably around 40 mph once the convertor has locked up. at first i mistook it for a misfire and found a burnt plug wire which didn't fix the problem when replaced. also fix a few vacuum leaks. i call it a vibration but it is not consistent, sometimes it won't do it until you put it under more of a load and sometimes you can literally feel it stop and start. i know my way around my car pretty well and cannot figure this out. went to the track to gauge how bad it is and my mph is VERY low for what it has done before (95 compared to 102). it has thrown a code for each o2, but not at the same time. also threw an EVAP code and the idle is high but will return to normal after a second or 2 with a quick rev
i am at a loss. i'm sick of the thousands i've put into it hoping to fix this problem. i'm almost ready to take it to a shop and make it their problem
what in the hell would i do to check that? i'm open to pretty much any suggestions as to possible problems, but if that is the case i'll have a shop do it
i've had a bad trans mount, it is nothing like what it felt like. it also does it sitting completely still at a redlight in drive, and the rpm's will pick up after a second and it smooths out completely. and something like that wouldn't kill my mph that bad i wouldn't think
update! just walked out to check my vacuum lines where the egr was deleted. happened to accidentally touch the #7 injector and the connector just popped free. plugged it in, double checked all the others and now the car runs smooth as ever with all the power its been missing
very, i realized its missing the metal clip on the #5 and #7 injectors that hold it in place. probably got lost by the mechanics that replaced a blown headgasket 2 years ago. anyone know if you can get just the clips somewhere? the car will be getting tuned soon so if not, i'll go ahead and order some slightly bigger injectors for the trip to tick/pcm4less
