Tools & Fabrication - Best Valvespring Compressing tool?
I'm going to have to buy a new one because the one I have it to big to work under the cowl of these 4th gens....so which one are you guys using??? which works the best??? I've seen one that you turn a nut down to compress the spring and another that you use a ratchet to turn and compress the spring...which is better?
vettenuts
05-01-2009, 04:47 AM
The Crane tool, also so by Vinci High Performance is the best one out there. Does two springs at once and is an exact fit so doing the back cylinders is not as hard.
gillbot
05-01-2009, 07:44 AM
I use the crane tool myself, makes it much easier.
MBC Racing
05-01-2009, 08:24 AM
Crane tool. Worked awsome. Especially on the back cylinders!! Used it on my GTO and Z.
mebuildit
05-01-2009, 09:01 AM
I've always used Buxton Engieerings spring checkers. They cost more and are a piece of art. Here is the link: http://www.buxtonengineering.com/on_head_valve_spring_tester.php
99_SS_LS1
05-01-2009, 09:08 AM
I've used "Tim's tool" for two swaps. Works great, and is inexpensive.
bigboykilroy
05-01-2009, 09:36 AM
+1 for the crane tool awsome !!!
yomama
05-01-2009, 09:51 AM
+10000 for the crane , its the shit
vettenuts
05-01-2009, 11:02 AM
Whatever you do, don't get one of the cheap ones with the two claws and the knob on the top. It will scratch the spring surface and could cause spring failure down the road on a high performance surface treated valve spring.
04gtoBMXracer
05-01-2009, 11:19 AM
Crane cams tool worked great for me.
Chrome355z
05-07-2009, 02:16 PM
Where can you buy the crane tool now?
I can't seem to find the LSX one on Summit anymore...
gillbot
05-08-2009, 08:55 PM
i got mine from jegs
01ssreda4
05-09-2009, 09:16 AM
i agree.........:D
Damian
05-14-2009, 10:39 PM
x 1 million
01formula6
05-15-2009, 08:28 AM
I'll throw in another vote for the Crane tool. It's an absolute breeze to swap springs. I got mine from SDPC ------>
budhayes3
05-16-2009, 10:04 AM
Crane tool hands down :)
I'm having a hard time finding the crane tool anywhere, where did you guys buy yours? right from crane?
1sick'98WS6
05-22-2009, 05:29 PM
I had a hard time finding a crane tool in stock. I ended up paying a little extra and buying it from jegs
spaz1
05-22-2009, 06:01 PM
just get tims tool (http://www.ls1tech.com/forums/tools-fabrication/317675-tims-valve-spring-tool-now-available.html)it worked mint for me. His hose is a bit hard thow I got it but ended up using the hose off my compression tester.
99blancoSS
05-22-2009, 06:41 PM
SpeedInc has revived this tool :)
Badmire68
06-28-2009, 01:52 PM
good to see someone still has some of these. Since Crane went out of business, summit and jegs no longer has any.
I have started making my own but with a bigger radius to clear the double springs. My Crane tool would bind on those sometimes.
MrDrezzUp
07-05-2009, 01:05 AM
I am surprised when I see people recommending the Crane valve spring compressor. I did a few spring swaps with it and found it to probably be the worst spring compressor I have used.
Since the Crane tool, I have purchased a few other valve spring compressors. Ironically, the one I found to work best (by a wide margin) is the ~$15 dollar "KD 912" one. Super fast, easy to use, and the tool holds down the spring by itself (man power not required).
KD 912 - Modifications
Cut the tool in half, right at the upper hole, and then the tool then fits under the cowl with ease.
The bottom hole in the KD tool is actually a smidge too big for a rocker arm bolt. Use an appropriately sized (and strong) washer to remedy this.
When using the KD tool, a portion of the KD tool touches the cylinder head edge (the edge that the valve covers seal to). Place a piece of cardboard, rag, whatever...between this portion of the KD tool and the cylinder head edge, to ensure no markings occur.
