What lifters should I be using?
Old 05-01-2009, 01:06 PM
gmmusclecarman's Avatar
Default What lifters should I be using?
motor is a 408 with 246/254 custom cam, TFS 235cc heads. I was originally going to go with LS7 lifters but then was told that those wouldnt hold up in my motor. I was told to go with morel lifters which seem to be pretty good but they are alot more then i want to spend. I will spend the extra cash for the morels if thats what i need. What would you guys recommend?
Old 05-01-2009, 01:32 PM
PREDATOR-Z's Avatar
Morels are good for smaller base circle cams.
They were designed exactly for that purpose.
Old 05-01-2009, 11:02 PM
Do i have a smaller base circle cam? do you need more info on the cam to tell?
Old 05-02-2009, 01:33 AM
PREDATOR-Z's Avatar
Who is building your motor, go with their advice.
My 2c
Yes the Morels would be a good choice for you. Go to their web site and read more about them.
If you are putting that motor together yourself, do extensive research on your valvetrain setup.
Old 05-02-2009, 07:17 PM
im getting an HKE shortblock and i will be putting the rest together myself. they recommended the morel lifters but they are $550 vs $130 for the LS7's i had originally planned.
Old 05-03-2009, 02:40 AM
PREDATOR-Z's Avatar
That is your decision, I am not saying that LS7 will not work, but Morels are better. In any case, do not forget to get new trays and look at thicker pushrods (thicker than 5/16th or thicker walled 5/16th)
Old 05-03-2009, 11:50 AM
1320 killer's Avatar
comp R's
Old 05-07-2009, 09:43 AM
cookba's Avatar
whats the difference pros/cons of the Morel Lifters with link bar setup and without? theirs only like a $30 difference.
Old 05-07-2009, 12:25 PM
sscamaroburn02's Avatar
throw some comp lifters in their and be done. i had 2 sets of ls7 lifters collapse on me. Just my .02
Old 05-07-2009, 03:23 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We've had great results with the LS7 lifters & for basically 120 bux they're hard to beat. The Morel & Comp R will be nice, but you have to make the call if it's worth the $$ for you or not. With all the failures I'd stay away from the Caddy Race lifters, but we've had great results with the LS7 lifters.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
