Dark engine internals from Royal Purple oil?
I bought the car last year & started using Royal Purple oil, been using it for about 7000 miles. I just did a cam swap on the car this week, I noticed it looked real black inside the motor when I had it apart, inside the valve covers & timing chain area. Does Royal Purple do this? There isnt really a sludge buildup, just kinda dark in there. I will take some pics of the oil pump & timing chain tomorrow & post them up. When I changed my valve springs, I did a leakdown test & all cylinders showed real low leakdown, like 1-2%.
How many miles on it? Do you know if the person that owned it before used synthetic oil. Do you know if they changed the oil on time? If you want clean the inside of your motor,drain all the oil out change the filter and fill it with ATF. Run it for 10min then drain and change the filter. Yes, it is ok to run ATF in the motor. ATF is just like oil but has more detergent(cleaning additives). Better than any oil flush you can buy. Trust me it works.
Over at the new LSx site a guy named Sarge did an oil analysis and out of all the oils Royal Purple done the worst, even Wal Mart Super Tech done better! you might try searching around and see what all is going on with their oil.
I wont ever run RP again. After having tried RP, Mobil 1 and now GC I wont even consider the first two. Not saying I gained power or anything but the motor runs noticably smoother and far quieter than with either RP or M1.
I did notice that with RP though, it seems darker than most others, but I think its just a die issue.
Oh and paint it black, your a dick-I thought you were banned.
Depends on the RP you use.
If you use the stuff you can buy at VatoZone, I can see that..
but their XPR oil has done very well in UOA tests. You do have to special order that though and it's $10/qt.
PLEASE don't lump all RP oils into the same category. Don't be a parrot.
never heard of it either, where and how did you find this stuff? seems dumb to make a top of the line oil and not advertise/market/sell it in stores. 10 bucks a qt seems downright stupid. Do you run it?
I ordered it from Speed Inc once, and once from Summit or Jegs.
Here's a UOA on it:
http://speedtalk.com/forum/viewtopic.php?t=9482
BP Lubricants said it hired the independent laboratory Southwest Research Institute, in San Antonio, to analyze power output of gasoline engines with Royal Purple Oil and with BP’s Castrol oil for comparisons. “The results were provided to the challenger’s expert statistician who was not informed of the identity of the candidate oils,” NAD stated. “The challenger’s [BP’s] expert determined a 0.9 percent difference in power between the oils, which did not rise to the level of statistical significance, and is well below the 3 percent claim made by the advertiser.”
SwRI did additional tests to independently determine the differences in fuel economy, emissions data and engine temperature between Royal Purple and Castrol motor oils. According to SwRI, “there was no statistically significant difference between the fuel economy, emissions data or engine temperature between the two candidate oils,” NAD said.
Following its review of the non-anecdotal evidence in the record, NAD recommended that Royal Purple discontinue the claims, “Reduces emissions up to 20 percent or more” and “Reductions in emissions of 20 percent or more” because the studies on which the claims were based were outdated and not consumer-relevant.
NAD also recommended the advertiser discontinue its unsupported claim that Royal purple motor oil is “API/ILSAC Certified.” Noting that API and ILSAC licenses and certifications have many categories with different meanings, the NAD recommended that the company discontinue its claim that its synthetic oils are “generally ‘API/ILSAC Certified.’”
In fact, no Royal Purple products are certified to current ILSAC specifications.
The American Petroleum Institute licenses its trademarked Service Symbol, or ‘donut,’ for display on qualified engine oils, and also licenses the ILSAC ‘starburst’ logo for oils that meet the auto industry’s latest energy-conserving standards. In API’s online directory of licensees for its Engine Oil Licensing and Certification Program, Royal Purple has a total of 23 passenger car and diesel engine oil products listed, all licensed to use the API donut. Five of these may additionally display the words ‘energy conserving’ within the donut logo, but none of the Royal Purple products are licensable to the current ILSAC GF-4 specification and they cannot display the starburst logo.
So RP oil DID see a 1% increase in power, and doesn't conform to GF-4 specifications. Both great things. Conforming to new GF-4 specs would mean it had it's Zinc and other anti-wear metals cut in half or more because of emissions reasons.
Here's an independant test out of Australia showing bearing wear, the XPR is the old "R 51" just renamed:
http://www.animegame.com/cars/Oil%20Tests.pdf
i wasnt knocking their oil in anyway if it seemed like i was. i was just trying to inform the OP so he could research and determine what his possible problem may have been. I was also informed that a couple of the 6 speed transmission shops wasnt warrantying their transmissions if you ran RP becasue some of the detergents were breaking down the parts. Just something else to think about.
So your saying RP makes crap oil that isn't even as good as walmart oil and also makes kick *** oil?? Just based on those comments I would steer away from the overpriced dyed oil. And what are they hiding with the dye? Personally we have done oil tests at the race shop and royal purple motors had about??? 10X MORE wear than any of the others! I am one that believes in proven results, not just someone trying to bash RP.
