10 bolt axle length diff?
ok guys i put a set of LS1 axles into my LT1 10 bolt because they had 1/2 studs in them to use with my prostars. Im having a problem with the brake rotor rubbing on the caliper when the wheel is torqued down. My question is are the left and right axles the same length or is one longer then the other?
Thanks
Thanks
