Worn Motive 4.10 Pinion Gear?
Old 05-02-2009, 02:27 PM
transfan0186's Avatar
Default Worn Motive 4.10 Pinion Gear?
Pictures attached. I've had a horrible whine pretty much from the start with these gears. The teeth on the pinion appear to be very thin. I'm thinking this could be the problem? Just a worn pinion possibly from a bad install?
Tell me what you think.
Attached Thumbnails Worn Motive 4.10 Pinion Gear?-pin1.jpg   Worn Motive 4.10 Pinion Gear?-pin2.jpg   Worn Motive 4.10 Pinion Gear?-pin3.jpg
Old 05-03-2009, 09:06 AM
Anyone? Let me know if the pictures aren't enough. I took them with my cell phone. Also it's the thin teeth on the pinion that maybe causing the slop.
Old 05-08-2009, 01:53 PM
Yes it's a worn pinion gear. It was shim'd improperly by the installer. Answers the horrible whine it produced.
