Mutha Thumpr cam?
Old 05-02-2009, 04:39 PM
01SOMZ28's Avatar
Default ***** Thumpr cam?
just curious if this is a decent cam or not. I've never hered anything about it or seen dyno numbers.
235/249 .573 .558 109 LSA
Old 05-02-2009, 05:19 PM
ramdaspadhye's Avatar
http://www.youtube.com/watch?v=NeQ0jk-7Uzc
I wasn't impressed by the performance of the thumpr cams in the SBC's... You really need to have a cam spec'ed to your type of driving, but that cam does sound nice with 24 degrees of overlap...
Old 05-02-2009, 05:22 PM
SweetS10V8's Avatar
It made 95hp extra on a carbed 5.3L in a Car Craft article a few months ago.
Old 05-02-2009, 05:42 PM
01SOMZ28's Avatar
was it the same specs i have shown above or do you have a link to this by chance.
Old 05-02-2009, 06:11 PM
allngn_c5's Avatar
I too am curious about a bigger duration lower lift cam. Especially for making big power without killing the valve springs.
Old 05-02-2009, 06:17 PM
SweetS10V8's Avatar
It was the 227/241 version, ***** Thumpr. Ill try to find the mag, or the article online.
Edit: I found it, it is for sure the 227/241 Thumpr..
Originally Posted by Car Craft
Our first shot was a simple baseline of the stock 5.3 with the carb and headers, making a credible 337 hp and 351 lb-ft of torque.... Just bolting in this new Thumpr cam (it didn't even have a part number) pushed the peak horsepower from 5,600 to a nose-bleeding 6,800 rpm..... the peak power jumped from 337 to 433 with stock heads. That's a 96hp bump with a cam swap!
(Entire article) http://www.carcraft.com/techarticles/ccrp_0804_325_chevy_small_block_engine/gm_performance_parts_intake_manifold.html
Old 05-02-2009, 07:28 PM
I sure wouldn't want that cam as a DD cam as where it starts making power....
Old 05-03-2009, 05:30 AM
9secondsflat's Avatar
109...*** that...thats a track cam, not a street cam.
Old 05-03-2009, 02:27 PM
allthrotle's Avatar
Actually its far from a track cam, the whole comp thumper series cams are all show and no go. They designed these cams for the guy who only wants the sound of a choppy idle cam but still has good driveability. From a performance stand point theyre not that good.
Old 05-03-2009, 02:46 PM
TooLateVTEC's Avatar
Exactly...all bark and no bite.
Old 05-03-2009, 05:57 PM
SweetS10V8's Avatar
I dont know what you concider "bite", but 96hp is extreme bite....
Are you even speaking from any experience, or just what you have read on the internet?
Old 05-03-2009, 07:55 PM
allthrotle's Avatar
Well there is alot more out there that can offer you more. Ive talked to comp cams reps direct and theyve all said the same thing theyre designed to give you the lope of a big cam and thats it. From a performance stand point theyre not that great.
Quick Reply: Mutha Thumpr cam?
