Drag Racing Tech
What line lock do you have and how is it plumbed?
Old 05-03-2009, 08:04 AM
Intercooler2's Avatar
Default What line lock do you have and how is it plumbed?
Anyone have pics and what they put in for a kit or pieces?
Old 05-03-2009, 08:08 AM
z28rob18's Avatar
i used the slp kit 2 lines a switch and a seliniod was easy to put it and works great sorry no pics
Old 05-04-2009, 08:11 AM
LS1TECH Sponsor
Steve Burger's Avatar
Check our site for Pics.
Old 05-04-2009, 08:43 AM
Internet Mechanic
BlackScreaminMachine's Avatar
SLP here, check the pic. It uses the factory ABS block, look on the driver side strut tower, and see the difference.
BEFORE
AFTER
Old 05-04-2009, 12:30 PM
Man-Crush Warning
01sscam's Avatar
SJM here. Had the SLP one and the solenoid failed after a few months.
Old 05-04-2009, 01:10 PM
Internet Mechanic
I have had mine for 1 year, never an issue but with selinoids, either they work or they dont.
Old 05-04-2009, 01:42 PM
RZRSEDGE's Avatar
SJM here. Excellent product with the customer service to match!
Old 05-04-2009, 09:10 PM
NJNETSFAN's Avatar
I'm almost 100% SJM uses the exact same solenoid as SLP. The only difference in the SJM kit is the arming switch which makes it NHRA legal.
here's mine installed:
Old 05-04-2009, 09:24 PM
z28rob18's Avatar
i dont get y nhra requires a momentary switch
Old 05-04-2009, 09:58 PM
SJM Manufacturing Inc's Avatar
I'm 100% positive the solenoid is not the same :-). Our wiring configuration is completely different. SLP apparently liked our front mount design as the line configuration is very similar to what we initially designed before they decided to construct them on their own. That's about the only similarity to our kit.
A non-momentary switch is unsafe. You have to manually activate and deactivate it. …If the switch does not have feedback (LED or other easy visual notification), you may not know if it’s on or off. If it’s accidentally switched on (once again, no visual notification), you may be in a surprise the next time you tap your brakes and the fronts stay locked. Picture this happening going down the freeway after your passenger switches it on not know what he did (and you didn’t know he turned it on). ...Clean your car, switch it on with a rag…the next day your battery may be drained and you’re solenoid is burnt up.
Our circuit works similar to how your cruise control works. When you want cruise control, you first have to turn the master switch on. When you turn the master cruise control switch off, it’s impossible to accidentally activate cruise control.
Give us a call if you have more questions.
Quick Reply: What line lock do you have and how is it plumbed?
