straight pipe exhaust question
Old 05-04-2009, 03:12 PM
ssick1's Avatar
Default straight pipe exhaust question
hey guys im running 3 inch pipe all the way to the back is it better to get a muffler or to leave it like that???
Old 05-04-2009, 03:15 PM
Brad Hutchcraft's Avatar
If better you mean, to make it sound less redneck, then yes.
Old 05-04-2009, 03:21 PM
ssick1's Avatar
well it sounds good not redneck but i was just wondering if its better to get like a borla muffler
Old 05-04-2009, 03:28 PM
thunderstruck507's Avatar
you definitely need a muffler, there's no way it can sound very good like that
Old 05-04-2009, 04:09 PM
InsaneDomestics's Avatar
I would have to disagree. Its a matter of personal opinion, but for performance I think you should get a good flowing muffler to add a little backpressure. Not having enough will make your car run like $h!t. SLP is a good one to go with.
Old 05-04-2009, 04:25 PM
ssick1's Avatar
around how much can u get just the slp muffler for??? not the whole kit
Old 05-04-2009, 04:37 PM
redbadss's Avatar
you can get the loudmouth 1 resonator for around $70 and the lm2 resonator for like $93 on ws6store.com both are 3in inlet/3in outlet.
Old 05-04-2009, 04:57 PM
ssick1's Avatar
cool thanks!
Old 05-04-2009, 05:11 PM
teke184's Avatar
lol...lack of backpressure making your car run like ****...that's funny.
my 3" true duals with straight pipes still let the car run fantastic...LOUD but fantastic.
if anything it shifted the hp/tq peaks a little higher, but it still ran great.
put a 24" summit racing bullet muffler on there to just tone it down a little. takes out some of the rasp.
Old 05-04-2009, 05:41 PM
SSTAHOE6.0LQ9's Avatar
Default sound deflection design
you should really consider using the Edelbrock SDT kit # 5672 with 3 chamber muffler will satisfy any rednecks wildest desires
Old 05-04-2009, 05:51 PM
Siphon's Avatar
Old 05-04-2009, 06:04 PM
If you ran your pipe all the way back it would be ok. I could tell a difference from when I had mine off at the ORY and ran it back the rest of the way. When I had it off at the Y it would still pull hard but it wasnt as good as when I had it ran back the rest of the way.
Old 05-04-2009, 06:31 PM
teke184's Avatar
well i don't think it was the backpressure that fixed it.
otherwise why would guys run dual cutouts? or TDs even?
it was either in your mind, or something was wrong (false knock, air hitting the o2 sensors...etc).
remember...the purpose of performance exhaust systems are to reduce backpressure. so as long as you have enough exhaust length to allow proper scavenging (headers and a ypipe WOULD)...than you'll make the best power with the least restriction.
like i said it may have shifted your power peak around, making it feel more sluggish in the bottom end.
Old 05-04-2009, 06:48 PM
BLKNRDPREDATOR2001's Avatar
i've had from a flowmaster exhaust, to a dynomax bullet dumped before the axle, to a SLP LM1, to a Borla exhaust. After all those exhaust systems i settled for straight pipe. I took off the borla muffler and got a 3' pipe and clamped it in place of the muffler. I used some Corsa clone tips. its real loud but it performs better in my opinion. Check my exhaut sound clip on www.youtube.com type in BLKNREDPREDATOR2001. I have a TSP 383 stroker.
Old 05-04-2009, 09:44 PM
Yeah your right, I never really thought about it like that.
Old 05-05-2009, 04:50 AM
ssick1's Avatar
once again dude my car does not sound like a red neck all i said was if its better to get a muffler so chill with the redneck
