Drag Racing Tech
400RWHP 6spds, what are you trapping?
Old 10-31-2003, 07:40 PM
Goober's Avatar
Default 400RWHP 6spds, what are you trapping?
In the 1/8 and in the 1/4 what are your trap speeds on drag radials or slicks.
Thanks
Old 10-31-2003, 08:12 PM
jruss's Avatar
well I can answer for a A4 with dr's I trapped 113
Old 10-31-2003, 11:07 PM
Savageite's Avatar
Well I made 401 to the wheels and the highest I have trapped is 118 mph. ALso my car weighed at about 3,480 with me in it.
Old 11-01-2003, 08:17 AM
Hardtop's Avatar
123+ in the 1/4, 96+ in the 1/8.
Bruce
Old 11-01-2003, 12:40 PM
AINT SKEERED's Avatar
My car is a full weight T/A with 12 bolt and it runs 115 in the heat and a best before 12 bolt of 119.39 with -1500 da.
I made 400.3hp/388 tq on the 30th at Thunder raceing. The race weight at the thunder shoot out last year was 3682 and now I have added a 12 bolt.
Old 11-01-2003, 09:11 PM
ls1 joe's Avatar
118 in my 3540lb camaro 94 in the 1/8
Old 11-01-2003, 10:58 PM
verbs's Avatar
117.6mph last year with ET streets and 120lbs more on the car at 2700ft density altitude.
I trapped 115.5mph at 5700ft density altitude this past August, so I'm about 2mph ahead of last year (according to correction factors), and hope for a 119mph pass in similar weather as my best mph.
Old 11-02-2003, 12:31 AM
CARTEK Racing
WS6TransAm01's Avatar
I traped 122.23 with 395HP
Old 11-02-2003, 01:15 AM
Goober's Avatar
Thanks so far guys, I'm trying to figure out whats up with my car, it made 402/378 with a 222/226 563/569 112lsa comp cam. I'm only trapping 91 in the 1/8 as compared with my stock cam I was trapping 90. Keep the replies coming.
Thanks
Old 11-02-2003, 08:41 AM
LS1Tech Co-Founder
Nine Ball's Avatar
waaaay back when I was 390-400 rwhp (the Formula), it ran 119-121 depending on weather. 3700 lbs, on drag radials. (11.6-11.9 ET range)
Tony
Old 11-03-2003, 08:58 AM
jruss's Avatar
damn I am wondering wtf my mph is errrrr of course I have never ran it in cold weather . Dry weight of car is 3575 113mph just seems low
Old 11-03-2003, 11:22 AM
Your car is heavy, I dont know how big you are but even at 125lbs it is 3700lbs. Also to get good mph you have to turn the engine hard. drive it like you stole it,even with my little hammer cam I shift at 6600 rpm's with a shift light . If you are going off the stock tach , it is not acurate if you have gears (i.e 4.10's). The tach cant keep up with the engine. It will rev faster than the tach in first and second and catch up some what in 3rd and 4th. Also , slicks or bias ply tires will make less than drag radials.
Old 11-03-2003, 01:24 PM
KGSloan's Avatar
i trapped 119 on street tires and 117 on the slicks. i'm hoping to hit 120 on the nitto's i have now since the weather is better now.
Old 11-04-2003, 05:11 PM
Nytmare's Avatar
Not quite 400, but I trapped 119 and usually 93 in the 1/8 !!! But this is all with a slipping clutch and f1 street tires !! Got sum 315/30/18 inch drags on their now and hopefully I can go ahead and tear up my clutch !!!1
Old 11-04-2003, 06:42 PM
Brains's Avatar
Last trips to the track I ran 11.905 @ 118.43 @ 3705 lbs and a different track ran 7.50 @ 95.0? ... Both of 'em spinning the ET streets w/ too much pressure in 'em The car made 408 RWHP, 375 lb.ft. at that time.
Old 11-04-2003, 11:04 PM
Goober's Avatar
What gears and cam do you have?
