LS4 Performance - Strut Tower Braces - Front Fitment Issue
BlueChevyGuy
05-05-2009, 12:51 PM
Hey guys,
I recently purchased a set of the strut tower braces from Don Rome. The rear bar went in with no problem at all. However, both front strut towers have a little screw popping up that hold wire harnesses. Those screws are right in the way of the front brackets. The brackets almost clear the screws, but not quite. I thought about just sawing the little screws off, but if there is another way to work without cutting on my car that would obviously be a better option. And yes, I did purchase the modified front bar that fits over the alternator.
Have any of you encountered this issue? It's a 2006 Monte Carlo SS.
P.S. - the car really handles a lot better with just the rear bar in place.
Thanks in advance for your help.
LS4SPEED
05-05-2009, 01:07 PM
I just took a hammer and chisel to mine. You may consider notching your brackets to fit. I was in a hurry to get them on before the wife got home to see that I bought another part for my car! LOL...
BuffaloSS
05-05-2009, 03:28 PM
Yep, same here. I didn't have a chisel but the hammer & screwdriver worked. I just relocated the wire harness to another nearby bolt. FWIW, while it is metal, I am pretty sure it serves no grounding purpose, so you don't have to attach it to anything metal/at all.
And yeah, the rear bar is the one to have. You won't notice too much more with the front one on.
Hidden mods FTMFW!!!! I feel ya, bro!
BlueChevyGuy
05-05-2009, 04:38 PM
Thanks for the responses guys. Hilarious about getting mods done before the significant other finds out!! Sneaky sneaky LOL! I guess I'll just relocate the wiring harnesses somewhere else - I bought the braces, you can bet I'm going to install them somehow! Even if the front bar won't significantly improve the handling over and above the rear bar gains, it will still look good under there.
Cheers.
Mels SS
05-05-2009, 05:36 PM
I just took channel lock pliers grabbed it low by the nose of the pliers moved back and forth
and it broke clean.
neilownz
05-05-2009, 11:45 PM
Used a little mini hacksaw. I think only one side had to be cut... can't remember.
BuffaloSS
05-06-2009, 08:16 AM
I can't remember if I reattached that harness to anything, or just stuffed it under the bar. I think I found a screw and put it back...not sure. I don't have any close ups of that area.
HOWEVER, I still have clearance issues with these brackets & bars...as do many others. It does not make the hood bulge, but it does rub. Mine is painted silver, and I have missing paint on the bar, and paint scuffs on the underside of the hood on the driver's side.
http://i539.photobucket.com/albums/ff359/cflynn233/DSCF6766-1.jpg
LS4SPEED
05-06-2009, 08:34 AM
Mines just bearly rubs also, no bulge or anything bad. It could probably be remedied with a tweek of the bolt flange. I think that could drop the bar down an 1/8th or so, just enough. If I ever decide to paint it that's what I'll do.
Panther427
05-06-2009, 11:56 AM
Nice underhood shot
BuffaloSS
05-06-2009, 02:03 PM
Thanks. I just replaced that shot with a better one...one without a POS taurus wagon in the bg. I figure the front of a WS6 is a little better. lol
dsgbraves
05-06-2009, 02:09 PM
Would anyone be willing to trace out a template of the brackets and mail it to me? pm me
Corny40
05-06-2009, 09:29 PM
Don't rip Don off. He's a great guy. They're not that expensive when you consider what you're getting.
neilownz
05-06-2009, 11:36 PM
Might as well make the whole thing custom if you wanna take the time to copy parts.
Nacho SS
05-07-2009, 12:00 AM
Dude thats messed up....:punch:
dsgbraves
05-07-2009, 12:13 AM
Im not trying to rip anyone off. I have the bars already that i will modify myself. and im going to make the brackets myself also. I knew some would think its a little messed up when i asked, but i figured it be worth a try before i go out and whip up a design myself. Im not trying to make money its only for me. I think what Don is selling is great, but i have the resources where i can do all the work myself so thats what im going to do. Sorry
neilownz
05-07-2009, 02:53 AM
Just start by making something that fits over the strut mounting holes like with cardboard/tagboard and mark out where the bar holes line up. Make the bracket a little larger to trim down, drill/tap the holes, etc. There is a slight bend that will need to be figured out but it shouldnt be that difficult depending on your skills. Could maybe make something with a hole saw if you want to be neat about it.
Speedoffastness
05-08-2009, 01:51 PM
How much for these and where do I go to order?
DP 08 GXP
05-08-2009, 08:31 PM
http://drcustomparts.com/HomePage.htm
