Single Digit Club - Gettin faster now
CHEVYMAN434
05-05-2009, 01:18 PM
Well i have just finished a bunch of work on the camaro.It is still a stock bottom end with 90 thousand miles,Patriot heads,and cam motion cam.Using one stage of nitrous i was able to run a 6.36 @109 with a 1.31 sixty foot.The converter has to go back to be tightned up because it is blowing through in high gear.The air shifter wont even pick up the two three shift i guess because it is so high up in the revs.Tires still have to be screwed cause they are rotating one full turn on launch.It should be in the mid 5's soon as i get the converter back and spray a second stage.Better times coming soon..
camscam02
05-05-2009, 02:33 PM
very nice. similar to where i expect myself to be next time out on stock heads. having the same converter issues you are having.
whats the raceweight? how big of a shot? you can pm if you want it left secret.
CHEVYMAN434
05-05-2009, 04:19 PM
Not sure of the weight,but no interior,ac,bumpers and anything else not crutial to goin straight,but does still have power steering.lol...I am using a NX 200 wet shot and am picking up 202 to the wheels.
camscam02
05-05-2009, 04:39 PM
haha sounds like it is pretty light weight then, just doing some comparing to my car and seems we are pretty close. I would be right there prolly quicker on 200 in my first stage as well. but converter probs could hamper that.
im at 3360 though with full interior.
great great runs. wish we had more of these stock block fast cars around
BAKED
05-09-2009, 07:38 PM
How big of a second stage are you gonna spray? Must be a big one to knock off almost 1/2 a second!
Nice times BTW
CHEVYMAN434
05-11-2009, 01:32 PM
Yeah,well getting the converter tightened and rims screwed will be the most help,but i will prob go with another 200 dry
BAKED
05-13-2009, 05:17 PM
Good luck!
SIr RicCuS
05-13-2009, 05:22 PM
Holy shit! That's fast! :D
Congratulations! I can't wait to go that fast. 1.3x 60fts. are spectacular!
CHEVYMAN434
05-22-2009, 12:29 PM
Well shot the second stage and shot all the coolant out the tail pipes.It was on a spectacular run till it gave up. I will be putting it back together tonight and trying it again sunday.Just hope it didn't get a piston this time.
stumprrp
05-26-2009, 10:08 PM
car moves man, whats the specs on the H/C/I? how big was the second shot?
CHEVYMAN434
05-29-2009, 03:35 PM
The second shot was a 150 and it got a piston. Looks like it got water in it and then it died.Patriot ls6 heads and cam motion cam 236/242@.595-.605.New motor coming in a week.Goin to a 404 with a direct port system and a plate system. 8's comin soon i hope...
BAKED
05-30-2009, 01:22 AM
Sorry to hear that. Good luck with the new motor!
BTW what kind of tune up did you have in it when it popped? Jetting, timing, FP, plugs, etc????
CHEVYMAN434
06-01-2009, 03:09 PM
Had 22 degrees of timing tr8's aftermarket fuel system. The car was great,it was all driver error. I figured out you need to turn on the water pump before making a pass>lol......
camscam02
06-01-2009, 09:08 PM
22 degrees? holy shit! is it carbed?
if not, suprised it didnt blow up sooner?
CHEVYMAN434
06-04-2009, 09:43 AM
No its injected..but thinkin of goin to a carb setup
camscam02
06-04-2009, 12:05 PM
damn have you ever checked your plugs? that is a ton of timing based on what my car likes with a similiar setup. on a 150 we run 17 and it seems to be perfect.
weird. haha :confused:
ATVracr
06-04-2009, 02:28 PM
Better slow down or your gonna blow the 404 up to.
Wrong plugs, to much timing and who knows what else.
When you turn the 2nd kit on shit gets complicated.
tektrans
06-05-2009, 07:03 AM
that's gettin out bro!!!!!!!! Nice job!! :thumb:
CHEVYMAN434
06-05-2009, 08:41 AM
Yeah i will keep workin at it.But not to bad i think with no help and doin it all in the yard..lol
CHEVYMAN434
09-21-2009, 10:48 AM
Well i got the new motor in the car and took it to the dyno on saturday.It killed the trans on the second pass but still had high gear so i went ahead and sprayed it anyways just to get the tuning done. It has low dyno numbers but this car allways is low on the numbers. It made 610hp and 561 ftlbs on a 200 shot. Motor passes were really low i guess because of the tight converter.I made 600 before on the stock motor but it has picked up a bunch of torque on the new motor.The tuner could see it has a restriction in the intake and it started to drop off by six thousand,and says there is alot left by getting a fast setup so it can breathe.So new times coming real soon....
slowredz
09-24-2009, 05:00 PM
I would go Victor jr or gmpp trying to spray as much as you are for distribution purposes:nod:
CHEVYMAN434
09-29-2009, 09:58 AM
Powerglide w/pro brake installed...
dkbmxer002
09-29-2009, 11:33 PM
i remember when you were stock and just got the car... came a long way!
CHEVYMAN434
09-30-2009, 07:39 AM
Hey Paul what's up with ya? Yeah been workin on the car for a while now and its been payin off but just keep runin out of money...lol.. Im takin it to jackson next thursday to see what else i can break.. Mid 5,s on one gun i hope
musclecity85
09-30-2009, 08:18 PM
damn that car is flying man..good to see you got it back together! i might have to make a trip to jackson
dkbmxer002
10-04-2009, 07:17 PM
damn! good luck! i have some decent goals myself :D
CHEVYMAN434
10-07-2009, 09:42 AM
Well not gonna make it out with the car tomo. Still waiting to hook up the two step
CHEVYMAN434
10-18-2009, 09:13 PM
Went to the track tonight and it wasn't what i was lookin for. Ran a 6.21 @114 w/1.39 60'. It slowed down on the sixty foot goin from the 350 to the glide.And the new motor just dont wing like the old stock bottom end. It still has the stock z06 intake on it so i will try a fast setup because when i was gettin it tuned it leveled off at 6200.Tuner says it runs out of top end and he can see it in the map sensor. This was on one 200 wet shot also. Havnt started to bring in the dry yet,just wanted to see if it would stay together first.lol...
CHEVYMAN434
10-20-2009, 08:20 AM
http://www.youtube.com/watch?v=XQOExaEzTmI&feature=channel
