Not charging
Not charging
Well, my buddies 95 T/A isn't charging. We tested the alternator at Advance and it passed. We checked the wires and they are good. The exciter wire from the harness has 12v coming from it. The alternator has a magnetic pull to the back of it. I was told that it meant it was charging. It is reading 12.09V on the volt meter at the back of the alternator. I let him use my alternator and we have the same results. Has anyone ever seen a bad gauge cause the alternator not to charge? It only reads 8v.
-Thanks
-Thanks
It was dead, we now have an Optima Red Top. Works like a champ.
Okay the problem is solved. My buddy is the type that likes everything.....pretty. He had the accessory bracket powder coated and it wasn't getting a good ground. Car had alot of bugs. Thanks for the input guys.
