Drag Racing Tech
315-35-17 DR vs 275-60-15 slicks
Old 05-05-2009, 08:00 PM
cbr600rx7's Avatar
Default 315-35-17 DR vs 275-60-15 slicks
I ran down to test and tune on sunday and had a few traction issues with the MT DR's so i am thinking about going to a full slick. My question is will going to a slick give me greater traction and better 60 times vs the DR's.
I love the DR's on the street but i hate burning up my street tires at the track and i still have some room left on my converter to leave a little harder since the highest i could ever leave was around 2400-2500 on a 3200 stall converter if i went any higher i was just spining.
Any help would be appreciated. I just looking for some input before spending the money on a new set of tires.
I did try a few diffrent pressures from 20psi to 30 psi and still had very little luck hooking at higher RPM's
Old 05-06-2009, 02:27 PM
ndfrsd6's Avatar
well to much air to begin with i was running 16 in mine depending on track conditions ....what gear do you have .......a 26 in tall slick should work for you they would be more consistent IMO
Old 05-06-2009, 03:18 PM
tomcowle's Avatar
275/60/15 would be the better of the two, taller sidewall is your friend.
Old 05-06-2009, 07:02 PM
cbr600rx7's Avatar
Running 3.42.
Old 05-07-2009, 12:57 AM
kmracer's Avatar
with a turbo setup you want taller gearing (taller tire = taller gearing), and the side wall is only going to help traction. what brand tire are you running? what pressure? what do you have done suspension wise?
Quick Reply: 315-35-17 DR vs 275-60-15 slicks
