NEED help - Question about moser 9" gasket??
Okay Heres the deal. I have a 1994 camaro z28 with a moser 9" rearend. Last year I took the car in a ring/pinion shop to have a detroit truetrac posi installed. Anyways long story short a year later I noticed there is a leak coming from the rearend. Turns out my STS turbo pipe is resting on the rearend vent. Completly blocking the vent from breathing. Now I have a leak coming from the rearend. It's been leaking everytime I drive it - I beleive the gasket is bad. I have two questions 1) Do I just use rtv for a gasket sealer or should I just use a gasket. 2) When I fill it back up what stuff should I use - weight and all and how much bottles will it take. - Thanks - Mike
