Anyone have any experience with LUK products?
Old 05-06-2009, 03:30 AM
UnZFeat'd's Avatar
Default Anyone have any experience with LUK products?
I have a LUK clutch pressure pate, master cylinder with drill mod, clutch disk, and slave cylinder. My problem now is that my pedal is super soft and just doesnt come back up when you press it down unless you pull it back up. Anyone know how this problem can be taken care of? Thanks
Old 05-06-2009, 03:08 PM
ibanez7's Avatar
if I remember right LUK is who makes the ls1 and ls6 clutch.
how old is your master and slave
Old 05-06-2009, 03:10 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Many people who drive cars with manual transmissions have had experience with Luk clutches - they are a huge OEM manufacturer, and are who designed/built the clutches that came stock in these cars.
As for your problem, it sounds hydraulic related, but who knows...
Old 05-06-2009, 03:16 PM
slayerized6's Avatar
LUK manufactures the ls1, ls6, and ls7 clutches as well as every other clutch in a GM car.
bleed the system. your probably got air somewhere in the lines
Old 05-06-2009, 03:24 PM
thesource's Avatar
Sounds like it need to be bled out.
Old 05-06-2009, 04:00 PM
UnZFeat'd's Avatar
well, its definately gotta be the hydraulics. The only thing im thinking of is some kind of problem with the hydraulic line. The master and slave are both about a week old, and have exactly ZERO miles on them. I just replaced them and did the drill mod. Is it possible that i drilled too deep when i did the drill mod? Now im not getting enough pressure inthe clutch to bring it back up?
Old 05-08-2009, 11:08 PM
bearcatt's Avatar
Most likely the problem is in the master cylinder. It doesn't matter if its new or not.
A few things you can do to get it working properly.
1.) Bench bleed or bleed the master seperately.
2.) Get a new GM complete pre-bled m/c
3.) Get a Tick-Tilton adjustable m/c. <--- Best solution.
Old 05-09-2009, 09:42 AM
DaddySS's Avatar
Get a mity vac and bleed the system, you'll be fine.
Quick Reply: Anyone have any experience with LUK products?
