Question about nozzle placement..
I am running in SD mode, so I don't have a MAF and I have a 4" cone filter attached to the throttle body.
I would like to install the nozzle in the end of the cone filter, but have concerns about how it will work since the nozzles are designed to spay a 90 degree pattern which would make it spray right into the filter material.
Would this work like this or should I find a nozzle that will spray straight out the tip?
