WTF Over???!!!
WTF Over???!!!
I'm baffled! Can you all do me a favor? Read the stats and all in my signature for Devon, the black 97 SS Camaro, and tell me if this sounds right to you! I think its WAY slow! Also I am at 600 Ft elevation.............
1st Run:
Reaction .5224
60 Ft 2.6645
330 Ft 6.7382
1/8 ET 10.0495
1/8 MPH 74.28
1000 ET 12.8741
1/4 ET 15.2415
1/4 MPH 95.30
2nd Run: (rpm's too low on launch, almost stalled)
Reaction .4735
60 Ft 2.7603
330 Ft 7.9528
1/8 ET 11.4235
1/8 MPH 70.32
1000 ET 14.3696
1/4 ET 16.8088
1/4 MPH 92.75
3rd Run:
Reaction .5103
60 Ft 2.6669
330 Ft 6.8210
1/8 ET 10.1301
1/8 MPH 74.34
1000 ET 12.9594
1/4 ET 15.3494
1/4 MPH 94.48
4th Run:
Reaction .3308
60 Ft 2.9216
330 Ft 7.2584
1/8 ET 10.6337
1/8 MPH 72.92
1000 ET 13.5140
1/4 ET 15.9388
1/4 MPH 93.09
5th Run
Reaction .3923
60 Ft 2.6614
330 Ft 6.7606
1/8 ET 10.0532
1/8 MPH 74.48
1000 ET 12.8780
1/4 ET 15.2530
1/4 MPH 94.98
6th Run:
Reaction .2753
60 Ft 2.7283
330 Ft 6.8565
1/8 ET 10.1697
1/8 MPH 74.16
1000 ET 12.9980
1/4 ET 15.3704
1/4 MPH 95.12
Seems slow as hell to me!
1st Run:
Reaction .5224
60 Ft 2.6645
330 Ft 6.7382
1/8 ET 10.0495
1/8 MPH 74.28
1000 ET 12.8741
1/4 ET 15.2415
1/4 MPH 95.30
Reaction .4735
60 Ft 2.7603
330 Ft 7.9528
1/8 ET 11.4235
1/8 MPH 70.32
1000 ET 14.3696
1/4 ET 16.8088
1/4 MPH 92.75
3rd Run:
Reaction .5103
60 Ft 2.6669
330 Ft 6.8210
1/8 ET 10.1301
1/8 MPH 74.34
1000 ET 12.9594
1/4 ET 15.3494
1/4 MPH 94.48
4th Run:
Reaction .3308
60 Ft 2.9216
330 Ft 7.2584
1/8 ET 10.6337
1/8 MPH 72.92
1000 ET 13.5140
1/4 ET 15.9388
1/4 MPH 93.09
5th Run
Reaction .3923
60 Ft 2.6614
330 Ft 6.7606
1/8 ET 10.0532
1/8 MPH 74.48
1000 ET 12.8780
1/4 ET 15.2530
1/4 MPH 94.98
6th Run:
Reaction .2753
60 Ft 2.7283
330 Ft 6.8565
1/8 ET 10.1697
1/8 MPH 74.16
1000 ET 12.9980
1/4 ET 15.3704
1/4 MPH 95.12
a buddy of mine is in Denver at 6000 ft with a stock LT1 Camaro and ran a 15.1 with a 60 ft of 2.5 seconds....I am at a lower elevation, with a crapload more stuff done to the car, and he beats me??? REALLY?
sorry just read the post itself. you could maybe try fixing your 60 foot times, get them down a whole second and youll see 13s as said above. what kind of tires are you using? try underinflating them? like 20 or so psi i think is normally used, right guys?
I would love to......but it wasnt me that was doing it! At 3000 RPM launch I bogged and sometimes almost stalled. At 3500 RPM launch I spun an INSANE amount......couldn't find a "middle ground" and that spin was almost half throttle
Brand new Goodyear Eagle F1 275/40/ZR17 tires not even a month old, Corvette 9.5" rims, 3.73 Gears, 3000-3500 RPM launch, Manual, Eidback Springs, BMR SFC's, Eidback LCA's, BMR Strut Tower Brace, BMR Panhard Rod, stock tire pressure
PIBSAW - Problem Is Between Seat And Wheel . No offense but you need a lot more seat time. Those 60's are HORRID. I think a Geo on an oiled down track can match them.
Get the short times where they should be and your ET will plummet . Practice Practice Practice!!!
:edit: Damn just took a closer look at your mods. A 2.7 60' should not "almost stall" a HC LT1. Even with a crappy start it should mph much better then that - those are worst then stock trap speeds. Scan it, check for crossed plug wires, pull every plus and examine them, do a leakdown test, check fuel pressure, etc. because something is seriously wrong. I'm thinking at least two cylinders are not firing.
Damn! My car cut 2.3-2.4 60's on street tires and still ran 14.1 at 101.86 with the clutch slipping all the way down the track. Your mph is way to low to ever see a 13. Switch the plugs to NGK's and check the Opti. Hell if you have cats they might need replacing. Sounds like the car cant breath.
I ran a while back and ran a, (dont make fun of me) 16.047 with a 2.514 60 foot. I still trapped 95.99 mph. That is with a cold air intake, gears and a homemade tune. I spun worse in second than first due to oil on the track.
Even with a bad 60 foot you should be trapping alot higher than that.
like I said... at 3500 RPM launch they went into a DEAD spin even at half throttle....at 3000 RPM launch, the car bogged and almost died....I had to double clutch to get it moving again
