Any problem with installing a higher pressure pump with stock injectors?
Old 05-06-2009, 11:54 PM
Lopoetve's Avatar
Default Any problem with installing a higher pressure pump with stock injectors?
I'm not planning on keeping the stock ones, but one of the few things I'm ~not~ comfortable with is dropping the tank - just not enough room to do it.
That being said, I'd like to have the pump installed by a competent shop (I've got a great one), but I'd like it done first so I can have it ready before I do forced induction and the new injectors - will there be any issue with a higher pressure pump (namely the Walboro in tank pump) with the stock injectors?
Old 05-07-2009, 12:31 AM
jetlag's Avatar
No you will be fine.
Old 05-07-2009, 06:04 AM
69LT1Bird's Avatar
It is still regulated to 58psi unless a different regulator system is installed, so the actual pump pressure doesn't matter. The advantage of a better pump is more volume.
Old 05-07-2009, 05:20 PM
Lopoetve's Avatar
right, I should have realized that. Thanks
