best way to remove swirl marks?
i have a black cts-v with swirls. what is the best way to remove them? scuff and clearcoat it all? or just a product and buffer. i know there will always be swirls, but how can i get rid of most of them quick
A high quality buffer, 3m Finesse it compound for dark colors, and then a good wax job by hand will be pretty much all you can do. Black is a tough color to deal with. There will always be a little bit of swirl action left,
Me To! I wonder why the damn hood gets all f'ed up so easy? NBM is a bad *** color though. If you buff it with a Porter Cable and look really close into the paint you can see so many flakes, its looks all 3D like it had its own little galaxy in the paint
meguiars swirlX! my friend tried compounding his entire hood with polishing compound but used too much pressure and an old t-shirt to apply it with. of course he did it in a pretty dim garage too so he didn't realize it was doing damage until it was done. he came over and we re-compounded it all and waxed it and it looked okay. still tons and tons of swirls but not terrible. used swirlX today and it's honestly amazing. i did one small section to test and honestly couldn't believe it. the difference was almost as extreme as the picture on the bottle. it was on a black car too btw.
For best results I highly recommend a machine with foam pads. Buff with white compound (white waffle pad) if needed, then use 3M Perfect-It Ultrafina SE (blue waffle pad) which is an awesome swirl remover and finish with your favorite wax. (Klasse high gloss sealant)
swirl marks are perminat. using chemical like wax and swirl remover is just covering them
up .the chemicals that you wash your car with thin's out the life of the chemical you use on them thats why they all ways come back good luck bro I'm not a professional but hopefully this will help you make your descion
I wouldn't say the swirls are permanent, what polishing does is take the sharp angles off the swirl marks on the clearcoat.
Try to find someone who knows how to do a "proper" detail. Sometimes people call it "cutting" the clear coat. It is a time consuming process but when done right, It looks amazing.
Good luck, keep us posted
did a black suv today with a ton of swirls and scratches. the owner buffed it with new finish. I hit it with a dewalt rotary with a foam pad and the swirl remover by Presta. I got it from a paint supply place at the reccomendation of my painter, came out perfect with zero machine swirls, all it takes is the right product and some time
