AFM Oil Pump Pressure
Old 05-07-2009, 08:03 AM
sandking's Avatar
Default AFM Oil Pump Pressure
Upon searching, I found that if you were removing the AFM/DOD and everything to do with it, that the oil pump would be too much pressure without it. How much is too much? Would I be better off replacing it with a ported or standard pump instead? I am just swapping in a cam with bolt ons in a truck 5.3 engine. Is there any value for this high pressure pump? Would it be just a matter of the spring pressure in the pump would need to be replaced with one for an LS1/6 pump? Thanks for any info
Old 05-07-2009, 08:08 PM
sandking's Avatar
Anybody have any info on this?
Old 05-08-2009, 10:58 AM
sandking's Avatar
The only reason I am asking, is because I ordered a new OE LS2 oil pump from gmpartsdirect, but they said GM is back ordered and they dont know when they will have them in stock. If I can change the pressure in my pump, I would rather do that instaed since it is low mileage anyway. I just want to see if it's even possible.
Old 05-08-2009, 01:36 PM
org
org's Avatar
It would seem that any excess pressure or volume would simply bypass into the pan. Only so much oil can go through the passages, and the rest will bypass. What's normal pressure with the VVT and AFM working?
Old 05-08-2009, 03:19 PM
sandking's Avatar
I dont know what the normal pressure was, I have a donor engine from an '07 Tahoe thats not in my Blazer yet.
Old 05-08-2009, 03:32 PM
hirdlej's Avatar
I use the same high volume pump in my silverado that you're referring to. It's a non-afm engine. 50PSI hot idle. Just use the stock WHITE colored bypass spring to bring your idle pressure down from 60 to 50PSI. I repeatidly shift at 6200RPM's+ and have no oil starvation issues. Run what you have. Just find a stock bypass spring
Old 05-08-2009, 05:11 PM
sandking's Avatar
Cool!! Now where do I find one of these white springs?
Old 05-09-2009, 10:07 PM
sandking's Avatar
OK, now I am a little confused. I pulled my pump yesterday and the part number is 12556436. From searching, this pump comes up as a 2001 year pump. Thats fine, but is the spring the only thing that makes these AFM engines high volume? Just seems odd to me. If this is the case, I wont buy a new pump, instead just replace the the spring as hirdlej mentioned. Where can I get the correct spring? Thanks.
Old 05-10-2009, 10:07 AM
sandking's Avatar
Bump.
Old 05-10-2009, 04:10 PM
org
org's Avatar
The spring has nothing to do with the "high volume". The spring holds the relief valve closed: light spring, low pressure; heavy spring high pressure. By using the light spring, you reduce the pressure of your pump from whatever it may be for the VVT/AFM setup. I have a L92 without AFM, but with VVT. I plan to remove the VVT and will run the same pump.
Old 05-10-2009, 09:30 PM
sandking's Avatar
So, do I leave the pump the way it is and call it good?
Old 05-10-2009, 10:10 PM
bhop42's Avatar
I say leave it. I just put this pump in my 403 and with a remote oil filter my pressure is 50 psi hot.
Old 05-10-2009, 11:16 PM
sandking's Avatar
Did you use the pump from an AFM/DOD engine?
Old 05-11-2009, 05:57 PM
sandking's Avatar
Bump.
Old 05-12-2009, 10:22 AM
sandking's Avatar
OK, last bump before I throw in the towel
Old 05-12-2009, 05:03 PM
bhop42's Avatar
Yes. That's what I was saying in my first post.
Old 05-12-2009, 08:56 PM
sandking's Avatar
Just making sure, thanks.
Quick Reply: AFM Oil Pump Pressure
