Truck manifolds have very different size openings (40%) - isn't it a problem?
As title says... Truck manifolds have very different diameter openings, difference in area is 40% which is quite a lot and will cause difference in backpressure and respectively EGT.
Do you guys enlarge the smaller one, or do you just ignore this?
I think that's partly because you can't really see/measure problems caused by these manifolds. But if 2 banks breathe differently, I'd say it can't be good. Didn't anyone ever burn passenger-side pistons? Wasn't it partly due to higher EGT in this bank?
I hope some gurus will shed some light
