ac will not come through vents
It switches between floor, dash and defrost on a vacum. If you look up in the corner between where your computer is and the motor youll see a little black line. Thats the line that goes into your firewall to switch your controls. Follow that around and see if its broke somewhere.. It "T's" by the engine.
So, it come from the engine and "T's", one goes thru the firewall and the other goes inside the loom up to the passenger side corner where there is a little cannister.
its a tiny black hose that attaches to the rear of the intake manifold. I messed up mine while swapping intake manifolds and now i have the same problem. just reach your hand to the back of the manifold, its on the other side of where the brake boost line connects.
This has happened to me twice. It can be a plastic bypass valve. They sell them at autozone for like 2 bucks. It is pretty small right next to the computer and it has three hoses going to it.
