Rebuild Rear end??
Rebuild Rear end??
I was thinking of rebuilding the rear end instead of replacing it with a different one. Is it possible to stay with the 10-bolt and rebuild it to handle 500 HP? It's an automatic transmission with 3200 stall and I don't plan on a lot of track time. What would be the best things to upgrade and what would be a waste of time to upgrade? Or would it just be cheaper to replace the rear-end completely?
Check out this link as well:
http://www.highperformancepontiac.co...ild/index.html
It's up to you. If you're going to put drag radials on it an try for best ET's, then I'd say replace it with a 12 bolt or 9 inch. But if it will only see the track on occasion, with street tires, then I would say build the 10 bolt. That's just my opinion though.
