PLEASE look at these throttle bodys!! NEED advice before I purchase!!
First one is a Nick Williams 92mm....its at the bottom of the page. It says it will work with a FAST90 and that is what I have but I dont know of anyone using a 92MM...I know its just a tad bigger but will this mess with anything. Also will my IAC and TPS swap over ok??
http://www.thunderracing.com/catalog...vid=3&pcid=180
Second one is the standard Nick Williams 90mm that I assume everyone is using. Just seems that its a good price...did these come down a lot recenty??
http://speed-eng.com/store/nick-will...dy-p-5478.html
Both are the same price at $377 so which one should I go with....THANKS!!!
You have any experince using the 92mm on the FAST90 or what??
The 9" isnt to bad. I havent driven it in almost 5 months so my memory is a little shady but it has a slight howl to it at hwy speeds. Nothing that bothers me...
Get the 92mm its probably just about the same size as the inlet on the intake manifold, you might have to handport it a little to match it. My 95mm throttle body is just about the same size as the 92mm inlet on the intake manfold, I was very suprised at that.
