crank no start. not sure where to post
i had the car running for 15 minutes prior, shut it off for about an hour and went and started it. After about 10-15 seconds of running, it just died. now it just cranks and wont start. its a 347 w/ 37lb injectors,fast 90/92. it has ran just fine for the past 3 weeks since doing the swap. any ideas? all the fuses/relays tested out fine. Dont think its the fuel pump, you can here it when you turn the key on and there appears to be fuel in the lines.
