Ticking/Jumping oil pressure
So this ticking sound started Saturday night along with fluxuation in oil pressure. I figured it was a loose rocker arm or a push rod so i popped off the valve cover on the and the driver side(which is where the noise was coming from) and the forward most rocker arm had play in it, but when i pulled it off and inspected it, the rocker was fine, and the pushrod isn't bent. There is still play so what could it be? Spring is tight and doesn't looked cracked.
