Oil for 9" trutrac
Old 05-08-2009, 01:56 PM
nealws6's Avatar
Default Oil for 9" trutrac
Moser 9" with trutrac and 411 gear. What oil should I use? THANKS
Old 05-08-2009, 05:09 PM
Pharcyde50's Avatar
I'm using lucas 80w-90. For a couple years with no problems.
Old 05-08-2009, 05:18 PM
subhumanzz's Avatar
same here.
Old 05-08-2009, 06:34 PM
LS1-450's Avatar
I use Schaeffers 267 80W-90 gear lube & will never use anything else. Mine's an 8.8, not a 9, but does have a true-trac. BITOG website will confirm my opinion regarding Schaeffers. There's alot of oil product test results on the site as well.
Old 05-08-2009, 08:21 PM
nealws6's Avatar
Thanks for the Info. My brother tells me to go with 85-140, is that too thick?
Old 05-08-2009, 08:43 PM
Ericbigmac83's Avatar
^ no, 80w-90 is what you want.
Old 05-09-2009, 10:28 AM
2001z's Avatar
Why is that? Just asking becouse i have ran 80-90 and now i run 85-140 weight recomended by my builder and would like to see how you answer this question. 140 weight will help for cars with gear wine also especially if you have a tunnel mount tq arm which i run that are known to cause a good bit of gear wine after install...
Old 05-09-2009, 08:42 PM
I run it cause that was what was recommended. i also have a tunnel mount tq arm with a bit of whine.
