3.73s 3.90s or 4.10s for my A4 TA
Old 05-08-2009, 03:03 PM
LS1TAUTO's Avatar
Default 3.73s 3.90s or 4.10s for my A4 TA
i got a catback and lid im lookin for more wholeshot power i need to launch on my opponets...anybody sellin gears and a stall i need both im just stuck on wat gears to get im lookin for a lot of low end power but i dont want my top end to go to **** either help me out A4 guys
Old 05-08-2009, 03:08 PM
AznMuscle's Avatar
What do you do with the car? DD? All out drag? A well rounded gear for A4s are the 3.73s for sure. If you want all out, then 4.10s, although top end will more than likely suffer, as well as gas mileage. I think most everyone uses 3.73s, be it high 10 sec low 11 sec mild builds, and mid 12 sec DDs.
Old 05-08-2009, 03:32 PM
1gt2nv's Avatar
I would go with 3.73's. When I get my gears, I'll get the 3.73's.
2.73's are junk. lol
Old 05-08-2009, 03:36 PM
Administrator
unit213's Avatar
You're wasting your money IMO if you are going to put a gear in the stock 10 bolt.
Old 05-08-2009, 03:44 PM
AznMuscle's Avatar
Atleast for an auto he has some life behind it. I probably wasted money on mine, but **** it. Pay to play. Hell, Ruckas99ss ran very low 11s on his ten bolt. Others have seen 10s, as I know you have seen. But we are all on a time bomb lol. How much is it nomrally for gears? I payed 250 for both my gears (used here) and install.
Old 05-08-2009, 03:47 PM
ecksz28's Avatar
I'd say go 3.73s. My friend threw 4.10s in his '94 auto and it was a little too much.
Old 05-08-2009, 03:53 PM
Administrator
unit213's Avatar
It's just money that could be spent elsewhere. Its normally $500 for a gear install. That's plenty for a 100 shot.
Old 05-08-2009, 03:56 PM
AznMuscle's Avatar
Lol. I kinda feel that way about spray right now...I COULD get a cheap set up for like $400 or so...but I want to do it right, and so that will be like $1k, since I don't like cheaping out in the least bit when it comes to vital parts like that. $500 for gear install?!?!?! Including gears?? Cuz the shop that I went too, and even Tony (zosick...you may have seen his youtube vids. 402 MTI zo6) took his old F bodies to this shop, and they did my gears and gurdle for like $125 or $150. I think I put like 10k or so miles on these gears...yea they whine a bit (richmond), but its not too bad.
Old 05-08-2009, 03:57 PM
ULTIMATEORANGESS's Avatar
i have 3.73s and like them alot. from a roll they kick *** and of course theyre better from a stop. i dont disagree about dumping money into a 10 bolt but its too late for me. ive already broke a couple.
Old 05-08-2009, 04:23 PM
BlackonBlackTA's Avatar
3.73s
Old 05-08-2009, 05:14 PM
TAtoad's Avatar
yeah, and theres pleeenty of threads on this already
Old 05-08-2009, 05:16 PM
allenwesley's Avatar
ive got an a4 and i also have 4.10s and i love them!! i say 4.10
Old 05-08-2009, 05:22 PM
Zaccagnini's Avatar
I say 4000 stall, no gears.
Old 05-11-2009, 11:20 AM
Chrome355z's Avatar
If you have to pay to have it installed just save the money for a better rear.
If you can do it yourself do it, gears are only like $175. I didn't even need the install kit, switching the factory shims from one side to the other got my backlash right. Pattern looked good. Just a hint of whine at 60mph, but I can only hear it with the windows shut and the radio off. I did pick up a new crush sleeve/pinion seal at the dealer.
Old 05-11-2009, 08:39 PM
1999Z28's Avatar
4.10s. you won't regret it. I went from running 12.69 @ 109 with headers and a tune to running 12.30 @ 113 with the 4.10s.
Highway driving isn't as bad as some say. 60 is at 2300 and 70 is at 2700. 80s at 3000.
I put a 12 bolt with 4.11s in and love it...except Moser can't make a quiet rearend to save their life.
Old 05-11-2009, 09:46 PM
dlandsvZ28's Avatar
Bear in mind that the taller the gear the easier they are to break.
You won't like cruising with 4.10's and your mileage will suffer too. At 70 mph I say your rpm's will increase by at least 200 jumping from 24/2500 to 26/2700 rpms.
2.73 revolutions compared to 3.23 revolutions compared to 3.73 revolutions compared to 4.10 revolutions really increases the rpms at 70 mph.
Compare that to a 6 speed that probably cruises around 2000 rpms with 3.73.
Old 05-12-2009, 07:28 AM
ecksz28's Avatar
I've seen tons of threads like this. Basically get 4.10s for M6s, 3.73s for auto.
Old 05-12-2009, 11:42 AM
01ssreda4's Avatar
i have seen lots of auto guys cut 1.5xs in ten bolts with some spraying out of the hole. And if labor is free, that makes $300 to do a complete rebuild with new gears. Not too bad, it can be practical to hang on the ten bolt for a while.
Old 05-12-2009, 12:29 PM
Jawsgear's Avatar
3.73 Ratio, Check out our site for pricing, use LS1Tech in the comment section and get free shipping.
Jeff
