PPI amp is cutting off...
I have a PPI amp in my truck and it's cutting off when I crank it up a bit. not screaming loud but pretty loud. All I am pushing is Boston Acoustic 6.5 componets and a JL Audio W6 10" sub. Also the gain is right at half.
Tell me what I should look for.
Thanks,
Sean
Thanks,
Sean
Check you resistence. Maybe you running your at a lower resistence than the the amp is stable at. Second, check your power and ground cable. Is it the adequete guage? Another thing, check your ground. Is at good point?
