It's alive finally.
It's alive finally.
I have been working on the LS3 418 since last fall. Made a lot of changes to the car. I finally got to start it today, but can't get the damn MSD 6010 to connect to my laptop. I have a good USB to serial adapter so I don't have a clue what is causing this problem.
http://s621.photobucket.com/albums/t...t=100_0403.flv
Had the same issue.. Try few different port numbers until one recognizes the box
this is the reasons I went carb'd rather than FI. Still had to F with a laptop and port numbers IRQ numbers etc.
Fixed the connection problem this morning. On some computers, pin 9 on the serial cable is used to activate modem software. When this is the case, the MSD won't connect and you can't swap com ports. I broke off pin 9, then I could swap to com4 and now it connects perfect.
