Anyone tried PRC 237CC full aftermarket casting heads?
Old 05-08-2009, 10:45 PM
vetteboyc5's Avatar
Default Anyone tried PRC 237CC full aftermarket casting heads?
Texas speed released them earlier this year, Im having trouble doing my homework to see how well they work..
Im planning on using them for a 408.
Are they better than the afr 225?
Old 05-09-2009, 01:43 AM
BigRich954RR's Avatar
Yea you going to have to really look around for info on them,Its out there though.
Very nice heads its what im putting on my 427 boosted motor. I think there better then afr225 for a few reasons. I think the deck is thicker/ I love the fact the rail is raised a little.
come with nice springs and for 60 more very nice springs which a great for high rpms or boost. Flow very good numbers. the prc 237 heads are flowed with out a pipe. alot of heads are flowed with a pipe cause it raises the flow numbers which looks better on paper.
Old 05-09-2009, 05:42 AM
vetteboyc5's Avatar
does anyone have them on their car yet, any real wold results? Im about to pull the trigger in the very near future
Old 05-09-2009, 01:35 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We're getting ready to run another big run pretty soon. After that you'll have some results. We have dyno results on the engine dyno comparing the cylinder heads your discussing, but I don't want to post the results. Needless to say they worked very well though!!
We recently had several 418s go over 670flywheel hp with the 237cc heads.
http://www.texas-speed.com/shop/item...d=992&catid=40
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 05-10-2009, 05:35 AM
Abdullah's Avatar
what is the valve angle of the PRC 237cc heads and the PRC 215cc heads?
i saw the PRC 215cc heads making very good power.
thanks.
Old 05-10-2009, 11:51 PM
Info changed there on a 13.5 *
Didnt know that i love these heads the more i learn about them
Old 05-11-2009, 05:25 AM
black00ssFL's Avatar
I saw TSP say 13 degrees for the 215cc head in another thread. I'm really liking the little bit of info that's coming out from actual owners of these heads (215cc). It's just about swayed me from the trickflows since I can save about $700 over them and get the same, if not better, performance.
Old 05-11-2009, 01:49 PM
vetteboyc5's Avatar
can we get more information In terms of availability and HP numbers on a 408 with a texas giant and ported 90 90?
Old 05-11-2009, 02:02 PM
Sales2@Texas-speed's Avatar
The 215's and 237's are 13.5ş valve angle
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 05-11-2009, 02:52 PM
Abdullah's Avatar
great, i thought they had 15* valve angle.
Old 05-11-2009, 02:58 PM
RAACCR's Avatar
Jason or Matt,
With the larger valve size and 13.5* angle, are the PRC 237's compatible with the valve reliefs in Diamond 11576 pistons?
Old 05-21-2009, 03:25 PM
vetteboyc5's Avatar
bump for more information- I just purchased these heads! Waiting for them to be built
Old 06-02-2009, 10:21 PM
Super Hulk Smash
JakeFusion's Avatar
Do these require 7.5" pushrods? If any longer, are they machined to accept 3/8" to 5/16" LS7 type pushrods?
Old 06-03-2009, 09:26 AM
Yes sir, they do require longer than stock pushrods (measure it to be accurate!). They work perfectly with a 3/8" pushrod!
__________________
Old 06-03-2009, 08:35 PM
Super Hulk Smash
JakeFusion's Avatar
Cool... does TSP sell them? I only see the 7.800" Comp Magnums on your site. I know you had Trend at one point - still an option?
Old 06-04-2009, 09:59 AM
I got them added. Thanks for pointing that out!
http://www.texas-speed.com/shop/item...d=152&catid=51
__________________
Old 06-04-2009, 11:36 AM
transaman98's Avatar
I have been in the head market for awhile and both the 215's and 237's i have looked into before. How would either of these guys stack up on a stock shortblock ls1 with a 224/230 114lsa cam? Car is a weekend warrior street car that rarely sees the track.
Old 06-04-2009, 05:11 PM
Abdullah's Avatar
the 237cc heads will not work on the LS1 block due they have large 2.10" intake valves, these heads are for 4.010" and larger bores. the 215cc will work on LS1 block becuase they have small 2.04" intake valve which are for the LS1 block bore of 3.898".
Old 06-05-2009, 01:52 PM
good to know. it seems like there isnt too much info out there on the 237's.
Old 04-17-2012, 12:49 PM
driver240's Avatar
i just finish to install PRC237 on my 427 LY6 and i lost 15wtq trough out the powerband and 10rwhp on top end so i removed them and re install my prc stage 2.5 heads..237 heads were 64cc and 5.3 stage 2.5 were 61cc...i was a very desapointed..!! put down 525RWHP and 506RWTQ with 2.5 and in a leaning condition of 13.5afr.. 516 and 493RWTQ with 237cc
Quick Reply: Anyone tried PRC 237CC full aftermarket casting heads?
