Largest Cam
Old 05-08-2009, 11:29 PM
LT1forever's Avatar
Default Largest Cam
What is the biggest cam you can have without having to change your gears? I've been thinking about ditching the 503 on my current setup and getting a custom cam. I'm not sure how the driveability would compare though.
Old 05-09-2009, 06:23 AM
96capricemgr's Avatar
You should change gears with a stock cam. Gear swap will make a bigger difference than the cam swap.
If you still have stock gears with the setup in your sig that is assbackwards.
I say that after having made basically the same mistake. I tried a little 210/224 ZZ4 cam before I had the supporting mods. The car's performance changed little, then as I gave it all the proper supporting mods those things resulted in BIG gains.
Old 05-09-2009, 02:14 PM
C5042081's Avatar
if he has 3.42 there not too bad for his current cam, you would benifit running 3.73+
Old 05-09-2009, 02:34 PM
CALL911's Avatar
There's not really a limit to cam size in regaurds to gears. It's just how driveable do you want the car to be. A big cam (or the stock cam for that matter) will drive much easier with bigger gears.
It really comes down to what you are looking for out of your car. If you are just not wanting to do gears because you know it will weaken your stock rear, then I would say at least put a girtle on it, put some gears in it, and stay away from sticky tires.
If you are looking for the best out of both worlds and the strength of your rear is not an issue, then I would go with a nice CC306 or GM847 cam and put some 4.10's in.
Old 05-09-2009, 02:59 PM
3.42s and a T56 makes 6th nearly useless, unless you like lugging the engine which is VERY bad. 4.10s are the way to go with a T56. You have to consider the .50 OD
Old 05-09-2009, 03:15 PM
95 TA - The Beast's Avatar
I have seen a lot of your posts, and your opinions are complete and utter stupidity at times...
3.42s and a T56 = 1500-1600rpm or so in 6th at 60-65mph which is perfect for fuel economy.
If you are saying that because most people put too big a cam in thier car and 1500-1600rpm is unobtainable for a given combo, then state that, but your blanket statement is what is useless...
Hell, make enough torque and you don't *NEED* anything more than a 3.42. Or make enough HP and run whatever gear, even a 3.23 or 2.73, you want.
Old 05-09-2009, 10:49 PM
Village Troll
SS RRR's Avatar
Sounded pretty straight forward to me. It looks as though it was an answer to a question. The subject is running the largest cam possible w/out a gear swap. Now I can say the same thing about this statement:
Extreme blanket statement and "useless" information. If you are wanting to putt around on the street then fine, but for 1/4mi performance you just can't run any gear and think it will perform well.
Old 05-09-2009, 10:56 PM
speed_demon24's Avatar
I don't even think about using 6th gear unless I'm doing 65+, and the backhalf of the 1/4 mile is a joke with 3.73's, it might touch 6k right at the traps. 4.11's would be a huge benefit in driveability and 1/4 mile performance in my mildish setup so I would have to agree gears would give a better gain over a bigger cam. And I don't think ~360rwtq at 3k is lacking lowend torque.
Old 05-10-2009, 12:55 AM
94dragbird's Avatar
Trust me, you will notice quite a difference with the gears. Go at least 4.10s with the M6
Old 05-10-2009, 02:05 AM
gregrob's Avatar
4:10 + m6 = mtfw
Old 05-10-2009, 05:15 AM
xx_ED_xx's Avatar
Originally Posted by gregrob
4:10 + m6 = mtfw
Agreed. and I see ta beast still has a huge 12 inch rubber dong up his ***
Old 05-10-2009, 09:16 AM
1500 rpms cammed is lugging the engine. Hell that is no good for economy with a stock cam.
I have a bone stock wagon with 2.56s and the heavily modded sedan with 3.73s. Now granted the wagon is heavier, but these cars get within about 3mpg of eachother. The wagon actually gains fuel economy if I make more use of drive instead of OD. OD at 50-60mph is down too low in the rpm range, even with the lowend torque b-body cam, it drives fine but the ultra low rpms hurt economy.
LOTS of b-body guys report fuel mileage gains with a swap to 3.42s with the A4.
Old 05-10-2009, 12:08 PM
slick1851's Avatar
Custom cam!
Old 05-10-2009, 03:22 PM
94dragbird's Avatar
Forgot to add that if you want any chance of hooking up at eddyville you will need at least a 28x10.5-15 with that M6. 4.10 + 1-2 shift + eddyville track prep = lost race and a big burnout(with brand new 226x10.5-15 ET streets) in a stock engine and trans bolt on car......
Old 05-10-2009, 07:13 PM
With 4.10s though the tire rpm wont spike so much if traction does break loose, meaning easier to catch it and get going again.
Old 05-10-2009, 10:04 PM
Village Troll
SS RRR's Avatar
it depends. heavier cars will not benefit at lower rpm especially if a driver keeps a constant overwhelming load on the engine which will cause the engine to work harder to maintain the same speed. drivers who are not vigilant to the changing terrain will easily waste fuel unless engine speed changed to copensate. basically the only way to run economically in 6th with a stock power/torque band is if it is on extremely flat terrain.
Old 05-11-2009, 08:41 AM
LT1forever's Avatar
Did you install your 4:10s yourself?
Old 05-11-2009, 05:01 PM
FASTFATBOY's Avatar
4.10's + six speed+ good tires+ ANY power= one BROKE *** 10 bolt.
The pinion is too small in a 10 bolt, stay with the gear you have until you get a 12 bolt.
Old 05-11-2009, 05:24 PM
ss.slp.ls1's Avatar
Sad but true...
Old 05-11-2009, 06:35 PM
bombebomb's Avatar
I have a hard time believing gears (at least any streetable gear) will make more of a difference than a cam with supporting mods, a good cam, not a baby jesus cam.
Quick Reply: Largest Cam
