Electric Waterpump Wiring Question
Old 05-09-2009, 12:18 AM
chevydriverz28's Avatar
Default Electric Waterpump Wiring Question
I recently purchased a mezire Electric waterpump for my LT1 SS. It didn't come with the wire harness to give it power though. Where can I run the positive to in the fuse box. I would really like it to run when the key is inguaged so I can have it running at the track even when the engine isn't running. Thanks in advance.
Brandon
Old 05-09-2009, 12:23 AM
Bad_tx_Z28's Avatar
painless make a relay kit for this waterpump. I suggest getting it. Would definatley save you alot of trouble it the pump shorts and frys your harness.
Old 05-09-2009, 07:31 AM
toy96ta's Avatar
Here is a decent write up for wiring it.
http://www.teamandersonracing.com/Pr...%20(Optional):
If you do a search on "Electric water pump" you should find a couple threads with install info...
Old 05-09-2009, 11:20 AM
caldercay's Avatar
Brandon
http://picasaweb.google.com/calder.c...37224064474370
Quick Reply: Electric Waterpump Wiring Question
