Warhawk 440ci Motor Build & Fogger Pics
Hey guys, I am just waiting on some custom head gaskets to show up and this baby will be ready to drop in.
Here are some pictures of the short block, long block, fogger, heads before and after clean up.
Heads Bare ... Before Porting :
Carb intakes on a vette require a large cowl. I don't think its worth spending the money on the intake, elbow, hood, and paint to make 20hp. What do you guys think ? Any dyno comparisons ?
I must say that if I dropped some food on the floor I wouldn't have any issues picking it up and eating it. Your work area is verrrrrrrry clean compaired to what im used to. Nice DP also
No idea what this means ? Someone care to share ...
The Warhawk block has very small coolant holes which you can see in the first pictures. They have designed this block with priority oiling all alluminum design with Ductile Iron sleeves. This bad boy should have no problem taking high compression nitrous applications.
OWN3D BY MY PROF!
What heads would you have gone with ? There are not to many options for the Warhawk 6 bolt pattern. ETP 4.1 LS7 heads ring in around 3500 with the Warhawk bolt pattern. That is almost double the cost of the world head right now. I did spend some cash to clean these up with hope that they will get me to my goal of close to 600hp on the motor.
