rear pro stars wont fit on my moser 12 bolt please help. Moser Guys Come In
I have a set of rear pro stars in 15x10 with 7.5 backspacing for f bodys, I had run them on my car before with no issues when i had my 10 bolt rear end i just had to grind the stock calipers like usual with the proper spacer and they fit right up no problems. but now that i have my 12 bolt with the stock calipers that i had previously grinded and i try to put my pro stars on and the wheel goes on but rubs a bit. Do you guys think i just need to grind more of the caliper. what do you moser guys run back there. thanks alot .
when i switched from the 10 bolt to the moser i had to re-grind the rear calipers as well.....i never figured out why and just chalked it up to the c-clip eliminators.....not sure it was the reason though.
