BBK 80mm TB will it work with LS6 intake?
Old 05-09-2009, 12:56 PM
SStriker's Avatar
Default BBK 80mm TB will it work with LS6 intake?
Im posting this here hoping to get a better responce...
Thanks
https://ls1tech.com/forums/general-l...s6-intake.html
Old 05-09-2009, 01:08 PM
TheLSgun's Avatar
Yes. That's what I'm running on my car.
Old 05-09-2009, 01:15 PM
SStriker's Avatar
OK cool thanks.
Do you happen to have a part no.
How did you get the trottle cable to work?
If you don't mind, can you send me some pics of your setup?
Thanks again
Old 05-09-2009, 01:28 PM
TheLSgun's Avatar
Originally Posted by SStriker
OK cool thanks.
Thanks again
No problem. Car is at the body shop so i can't get you any part no.
Here's some pictures:
Old 05-09-2009, 01:47 PM
SStriker's Avatar
OK that makes me feel alot better - thanks
one more. How did you get the trottle cable to work with this TB.
When I fit the BBK on the intake and put the cable on it and go WOT from the pedal, it only opens about 40-45 degress. Cable is to long
As you can see from my pics, the part where the cable goes is alot smaller.
But I don't see anything defferent done to yours.
Old 05-09-2009, 03:14 PM
Marc 85Z28's Avatar
There are 2 different throttle body cams, and each has it's own length cable. Instead of creating 2 holes in the BBK arm, they chose to include a spacer and new throttle cable bracket. You don't have that, and you need it.
Old 05-09-2009, 03:52 PM
SStriker's Avatar
I see.
Will I have to call BBK and see if they have what im missing?
Thanks for the info.
Old 05-09-2009, 04:15 PM
Marc 85Z28's Avatar
I see.
The throttle bump stop in the pic you posted is rusted - did you buy it used? If so why didn't the seller provide it? If he doesn't have it ask for a refund, give it back, and put on a ported stocker.
