PCM Ignition fuse
Old 05-09-2009, 04:03 PM
SINISTER-TA's Avatar
Default PCM Ignition fuse
I just helped a friend change out an Opti, plugs and wires on his 95 Trans Am. After everything went back together, the car wouldn't start. Further investigation revealed that is was blowing the PCM Ignition fuse immediately after tuning the key to the "run" position. We have tried tracking down the problem by checking all the wires ran off of that fuse. We cant's find anything. No pinched, cut, crossed or grounded wires.
Any ideas?
Quick Reply: PCM Ignition fuse
