Alternator problems
Old 05-09-2009, 10:35 PM
Harbs SS's Avatar
Default Alternator problems
Well i have a 99 camaro ss and i just replaced the alternator. The only issue i have is that the previous owner did a 1 wire rig which i believe is the exciter wire and i do not know which prong it plugs into.(he cut the harness off) I have searched high and low to see if i could find anything, but i found nothing. Can someone tell me where it plugs into and the GM part number for the harness thank you.
Old 05-10-2009, 06:22 PM
LS6427's Avatar
That little sucker goes all the way over to the PCM inside the harness.
