Broke SFC bolt
Old 11-02-2003, 01:01 PM
BadAndy's Avatar
Default Broke SFC bolt
I was installing my SLP SFCs and I ended up breaking one of the bolts that holds the tunnel brace under the Driveshaft. How bad of a thing is this? Should I really worry about it in the meantime before I drill/tap it? Thanks
Bad Andy
Old 11-02-2003, 01:25 PM
wrencher
wrencher's Avatar
I wouldn't worry a whole lot but you do intend to drill & tap it out later right?
Old 11-02-2003, 01:52 PM
glitch77's Avatar
Dont worry about it. But do fix it sometime.
Old 11-02-2003, 11:32 PM
BadAndy's Avatar
okedoke
Old 11-03-2003, 01:41 AM
DARK AGE 53's Avatar
You could just drill it out and use a nut instead of tapping the hole, use a grade 8 bolt/nut and torque to 27 ft/lbs. I would suggest you do this sooner rather then later, no sense in putting an extra strain on the one bolt that is holding it to the tunnel brace area. JMO
Al
