View Full Version : UMI Tunnel Brace Torque Arm Making Noise….
Fun-Formula98
05-10-2009, 06:36 AM
So…Under deceleration and breaking over bumps my new UMI Tunnel Brace Mount Torque Arm make s a “thud” sound. Anyone have this problem, or is it just me? :bang:
98Camarod
05-10-2009, 07:07 AM
Did you get the proper driveline angle?
Sure its not a broken trans mount?
Fun-Formula98
05-10-2009, 07:14 AM
0 degrees Stock ride height
98Camarod
05-10-2009, 07:28 AM
Check your trans mount. Mine was trashed before and on decel it would bang like you are mentioning.
Fun-Formula98
05-10-2009, 07:31 AM
Will do…BUT its fairly new… I replaced the stocker with an energy suspension mount.
Fun-Formula98
05-10-2009, 03:28 PM
UMI? Any thoughts? PLEASE?
stealth355tpi
05-10-2009, 08:29 PM
ive got the same problem. my mount is good and the angle is also at 0 degrees. but ive also got a spool so ive gotten use to the thud sounds. sorry i couldnt help but its normal from what i have heard.
metalmechanic
05-10-2009, 10:44 PM
i have all that new stuff to and does the same thing, its a trade off for better handling performance, I have BMR
UMI Sales
05-11-2009, 07:12 AM
Hello
The noise that you are hearing is the Torque Arms mounting bracket! Their are a few options to fix this. One is to relocate it to the second pair of holes (But you might have to grind some of the bracket off to get to clear the rear) and the second is just massage your tunnel for clearance (or let it go and it will make its own clearance) If you have any other questions feel free to ask and I will be glad to help!
Thanks
Brad :D
UMI Performance
05-11-2009, 08:14 AM
Hello,
Another thing not mentioned is to make sure the bolts that attach the torque arm to the rear bracket are very tight. These are the (2) 5/8" bolts that run through the torque arm and attach it to the bracket that attaches to the rear end. These bolts are only installed finger tight by us during assembly. Did you tighten these two bolts? If you did please double check them... it takes a lot of force to compress the 3/8" thick steel mounting plates we use. Tighten these two bolts as tight as you possibly can. If there is any movement there this will cause a thumping noise.
Also what Brad mentioned is something to consider as well. Is your vehicle lowered? Do you have an aftermarket rear end? These few things make a difference.
Let us know and we will be glad to further assist you. Thanks!
Ryan
Fun-Formula98
05-11-2009, 09:23 AM
Everything is TIGHT... Better handling and performance for a little "thud" now and then.... I can deal with that.
BTW... UMI has great customer service and their products are second to NONE!
stealth355tpi
05-11-2009, 09:35 AM
also just so you dont have the same problem i did, if you have an aftermarket rear like the moser 12bolt make sure u tack weld the 4 bolts to the torque arm that holds it to the rear. i broke the back half of the arm b/c those bolts came loose :mad:
Fun-Formula98
05-11-2009, 05:21 PM
Thanks, new rear is coming soon... I have a few decisions to make first...
UMI Performance
05-11-2009, 07:36 PM
Glad you are happy with the torque arm and service!
I highly suggest like mentioned to avoid the Moser 12-Bolt.. the Strange 12-Bolt is nice as well as the Strange S60 and Moser 9".. but those could be overkill.
Hope that helps!
Ryan
silverLSWON
05-11-2009, 10:15 PM
typical tunnel mounted torque arms. they always make the thud noise
